Bad alternator???
Old Aug 6, 2002 | 08:30 PM
reyderz's Avatar
reyderz
Default Bad alternator???
How can I tell if my alternator's not charging? Y volt guage says I'm running 12.1 volts and when the headlights come on it starts dropping. Shouldn't the volt guage go up when I give the car gas? Thanks
Old Aug 6, 2002 | 08:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Bad alternator??? (reyderz86)
You should read 13.x Vdc with a high idle and accessories on.
When my alt died it had no output and voltage was below 12 Vdc.
You can pull your alt and have it checked to be sure.
Old Aug 6, 2002 | 08:45 PM
dbwade36's Avatar
dbwade36
I just replaced mine. Bought a new battery first, but voltage low indicator came on shortly after install. Replaced my alt and problem was solved. volts read 13.8 or so now. They are very easy to replace, believe me. I am not that mechanically inclined and I did it myself in probably 30 mins.
Old Aug 6, 2002 | 08:55 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
In a perfect world, the volts should remain constant regardless of RPM, once you have gotten over the initial start up phase (10 to 30 seconds depending on how long the car has been sitting and how hard you had to crank it)
!2.1 volts is an alternator that is about to leave you stranded! I had one that crapped out in the middle of a busy intersection
Suggest you change it
Jack
Old Aug 6, 2002 | 09:51 PM
jfb's Avatar
jfb
The red battery symbol light should be on in your dash showing that the alternator is not charging the battery. 12.1 volts is indication of a discharged battery. Fully charged is 13.2 volts. Cold, you should see 14.3 volts on your dash voltmeter, engine running, low electrical load. Hot it will be 13.3. Idling with heavy electrical load , the voltage will be the battery voltage and should pick up to 13.3 when you get underway. 12 volts when you are underway and you have an alternator that is not working.
Old Aug 7, 2002 | 02:53 AM
Togo's Avatar
Togo
Default Re: Bad alternator??? (jfb)
yeah what he said!!!!
i had my alternator go bad a few weeks ago.....funny thing was, it was running at 11.9 volts at high RPMs and at idle it went up to 12.1 :crazy:
Old Aug 7, 2002 | 04:18 PM
reyderz's Avatar
reyderz
OK, thanks. I just bought a high amp alternator off ebay, I sure hope it's not the battery.
To Bad alternator???
