MAF position in CAI
Old Jan 12, 2015 | 04:05 AM
waljr's Avatar
waljr
Default MAF position in CAI
I am making a cold air intake to flow over the radiator on my 80 vette (yeah I know it's a c3 but it's miniram'd, so that puts it back in your court)
My MAF sensor is currently in a 4" tube to pod filter.
Are there any significant restrictions with MAF sensor placement?
Greatly appreciate any help
Old Jan 12, 2015 | 04:39 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
2 diameters. U want the entry tube to be straight for at least 2 tube diameters before the MAF sensor. This prevents excessive turbulence entering the MAF sensor. That would be at least straight for 8" for yours. Maybe a good idea after the MAF too.
Old Jan 12, 2015 | 04:50 PM
waljr's Avatar
waljr
thanks for the reply
8"-16" gee that makes it a very tight fit.
would it be ok to let it transition down after from the maf to the t-body
might be time for a rethink
Old Jan 13, 2015 | 01:41 AM
Cliff Harris's Avatar
Cliff Harris
The MAF screens are there to straighten out the air flow. See this article for an in depth analysis of the MAF and screens:
http://forums.corvetteforum.com/c4-t...post1584963813
The main thing you want to watch for is to make sure all the air going into the engine is going through the MAF. Otherwise the computer will get an erroneous picture of how much air and fuel to mix together. That is why the PCV system gets its air from the throttle body. That air will get mixed in inside the intake manifold.
Old Jan 13, 2015 | 02:10 AM
cardo0's Avatar
cardo0
U need the 2 dia straight before the MAF to prevent uneven distribution or at least minimize it. That is from Greg Banish of Calibrated Success: http://calibratedsuccess.com/
The 2 dia after the MAF is just my idea and nice to do if u have the room.
Hope this helps ya wal.
Old Jan 14, 2015 | 04:42 PM
waljr's Avatar
waljr
thanks for the reading material fella's.
I've re-routed some hoses & started a general mockup -I think I can make it fit
To MAF position in CAI
