The Camber Brace is on!!
Old Aug 6, 2002 | 11:47 PM
Bill Burkert's Avatar
Bill Burkert
Default The Camber Brace is on!!
Just got back from a short test drive and can really tell the difference up front. My GS is slowly getting away from its go-kart handling and becoming nice and precise.
I did take off the belt with a sepentine tool from Sears because I could not get the bolt all the way out because the belt was in the way. I also used the two smaller shims on each side when installing the brace. I put it in from the driver side with no real problem. My 16 year old son was a big help!. I recommend putting a piece of string through the shims(s) because they fall out easily then blind fishing for them occurs.
My son also noticed a big difference with the brace installed. :)
Old Aug 6, 2002 | 11:52 PM
Bill Burkert
Default Re: The Camber Brace is on!! (Bill Burkert)
I updated my signature!! A pitcure will be posted in the AM and a NOS 5174 is sitting in the garage ready to be installed next!
Old Aug 7, 2002 | 01:20 PM
1996man's Avatar
1996man
how hard was it to instal and how long did it take?
Old Aug 7, 2002 | 05:10 PM
Bill Burkert
Default Re: The Camber Brace is on!! (1996man)
The job was very easy and took about 90 minutes. Having the right tools was a plus and that being a belt remover. I don't know how anyone could have done the job without it because the belt portion around the air conditioner is in the way of taking the bolt out. I will say that it looks tricky when you first start but follow the directions and you'll be fine.
Old Aug 7, 2002 | 05:29 PM
Gary04Z06's Avatar
Gary04Z06
The installation is neglagible compared to the advantage the Camber Brace gives you. Just take yout time and it should be no problem. Great improvment to the handling. :chevy
Old Aug 7, 2002 | 05:40 PM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: The Camber Brace is on!! (Gary96LT4)
Arrrrgh, everyone makes it sound so easy.
Old Aug 7, 2002 | 05:45 PM
STL94LT1's Avatar
STL94LT1
Welcome to the "camber-brace" club.
To The Camber Brace is on!!
