brake safety question
Old Aug 8, 2002 | 12:03 AM
jsquared94's Avatar
jsquared94
Default brake safety question
Hey all,
the other day i pulled my front wheels off for the first time, as i finally got the locking lugnuts off (the lug key wasnt with the car when i bought it). anyways, on the passenger side the only thing holding on the rotor with the wheel off is the caliper. even with the caliper on i can move the rotor on the hub a whole lot in and out. the driver side rotor won't budge (maybe its just "frozen" on?)
is this play correct and safe? i understand that as long as the wheel is on and torqued the rotor obviously can't fall off, but i'm used to every other car having a huge castle nut or something, usually under a dust cap, in the center of the rotor holding it on. this is just bugging me- but really exciting seeing those huge calipers up close for the first time! :cool:
Thanks!
Old Aug 8, 2002 | 12:10 AM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: brake safety question (jsquared94)
You are correct. The rotors are not attached to the hub. On a front wheel drive car they are like you said with the castelated nut. I would try to figure out why your other rotor won't come loose.
Old Aug 8, 2002 | 01:55 AM
Corvette0096's Avatar
Corvette0096
Default Re: brake safety question (Bob86ZZ4)
You can use a loaded hammer that should get the one loose and it wont hurt anything.. Loaded meaning rubber hammer filled with lead..
Old Aug 8, 2002 | 10:56 AM
vettmech's Avatar
vettmech
Default Re: brake safety question (corvette0096)
The one that's not loose is rusted fast or "seized"......... yes a hammer blow can knock it loose.......
To brake safety question
