how much power will i gain....
Old Aug 8, 2002 | 01:56 AM
blackonblackLT1's Avatar
blackonblackLT1
Cruising
Default how much power will i gain....
Hey guys i was wondering how much power i will gain with an 86 vette if i install 58" throttle body and port match it,and also install a mass air flow sensor??
MY mods now are an....
Adjustable fuel pressure reg.
K&N air filter
low temp. thermostat 160
high perf. pulleys
straight through exhaust
B&B cat back
Old Aug 8, 2002 | 02:24 AM
vader86's Avatar
vader86
Default Re: how much power will i gain.... (blackonblackLT1)
a grand total of 0hp
58mm is worthless on a 350 TPI
Removing your current MAF for a new one is pointless unless yours is broken. But removing the screens in your current MAF is a good idea and might yield a few hp.
Old Aug 8, 2002 | 02:54 AM
RadPolo96's Avatar
RadPolo96
Default Re: how much power will i gain.... (vader86)
What he said...58 would only do something if you had new heads, cam and headers, somethin thats gunna need alot more air flow.
Old Aug 8, 2002 | 10:54 AM
Nathan Plemons's Avatar
Nathan Plemons
Well I've got a dyno proven 0 gain with a 52mm TB. I'm sure the 58 would at least double that gain.
Old Aug 8, 2002 | 11:58 AM
MTVette's Avatar
MTVette
Default Re: how much power will i gain.... (Nathan Plemons)
You'd probably see quite a power loss if you installed a 58 inch throttle body, since you'd need to remove the hood and the almost 5 foot-wide throttle body would give you too much air drag (j/k). :D :D :D
Actually, unless you have modified the cams, heads, and headers, your car won't need so much air that even a 52-mm throttle body can provide. Other bottlenecks are limiting your power, not the throttle body.
[Modified by MTVette, 11:05 AM 8/8/2002]
To how much power will i gain....
