88 doug nash conversion question
Old Jan 31, 2015 | 07:52 PM
hitekcm's Avatar
hitekcm
Default 88 doug nash conversion question
I posted previously with problems related to the Doug Nash 4+3 and rather than pay 5 Speed.com $1250 for a professional upgraded rebuild I figured someone here has swapped out this unit for another 5 or 6 speed trans.
Anyone know what Trans. will be a capable easy swap?
Old Jan 31, 2015 | 07:59 PM
c4cruiser's Avatar
c4cruiser
A ZF6 will fit and there are a number of members that have done that swap. But don't expect it to be cheap. It will be cheaper than a new TKO500 swap, but still will cost some.
Do a search using tags like "ZF6 swap". That should bring up some results that may even have step-by-step instructions.
Old Jan 31, 2015 | 11:34 PM
DanZ51's Avatar
DanZ51
Unfortunately that $1250 for a rebuilt DNE overdrive is probably the cheapest option, but if you're "handy" and bargain shop you can swap for as much as (maybe a little less) than the rebuilt OD.
Search for ZF6 swap, T56, or T5 swap; lots of threads. ZF is nice, bulletproof (OE) swap but can be expensive especially of the ZF needs to be rebuilt.
T5 can be done but are somewhat "light duty" unless modified. Availability of GM World Class type T5 can be spotty. Plan on a rebuild but it's a fraction of the ZF rebuild.
T56 are slightly more involved with installation mods and slightly higher costs. They are strong and can be made stronger with a lot of aftermarket support.
I went with the T56 after I stumbled on a deal I couldn't pass up. Do your research. Assess your ability and resources and have at.
Old Feb 1, 2015 | 09:09 AM
3JsVette's Avatar
3JsVette
To keep the price down on an alternative you really have to be committed to doing a lot of legwork (shopping and labor) yourself as well as not being pressed for time.
Old Feb 1, 2015 | 11:54 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I pulled the 4+3 out (of my '84) several years ago when it took a powder. I swapped in the Richmond 6 speed. Went in pretty smoothly (although it did require cutting the tunnel slightly for the shifter clearance). It's a nice shifting box (with the Long brand shifter).
Richmond had had some business difficulties a few years ago, and I don't know what their current situation is.
Old Feb 1, 2015 | 06:23 PM
hitekcm's Avatar
hitekcm
Default 4+3 trans swap
Thanks for the info, I'm on the hunt right now.
Old Feb 1, 2015 | 06:29 PM
hitekcm's Avatar
hitekcm
Thanks , just so happens I have a GM T-56 sitting around that I was going to put in my 65 Goat.
T-56 seems very large? I don't guess I would be able to reuse my stock console which is what I would like to do.
Would this bolt right up to the stock bell housing? would I need a different drive shaft?
I saw Hurst has a complete TKO 600 swap kit but I'm waiting for the ball buster price.
Old Feb 1, 2015 | 06:31 PM
hitekcm's Avatar
hitekcm
I like shopping and as far as labor, mine costs nothing, thanks guys
Old Feb 1, 2015 | 06:34 PM
hitekcm's Avatar
hitekcm
Could you use the stock console and how about drive shaft etc? Thanks a lot.
Old Feb 1, 2015 | 07:59 PM
hitekcm's Avatar
hitekcm
Default Did I just screw up guys?
After receiving the answers from you experts I went to ebay and saw a 95 LT-1 engine and 6 speed trans complete with computer, harness all for $1695
With only 80K miles, out of running car with no problems.
I made offer of $1500 including driveline and yoke , they accepted my offer !
Did I just screw up ???
Old Feb 2, 2015 | 01:55 PM
DanZ51's Avatar
DanZ51
No I wouldn't say you screwed up providing shipping doesn't bite you and hopefully the selling wasn't hiding anything. A good running T56 with bellhousing is in the $1000 - $1300 range. Your console remains although it will be modified a little. There are a bunch a threads on here about doing the T56. So a few of us have broken a trail for ya. I'd recommend reading them all but here's a couple to get you started.
https://www.corvetteforum.com/forums...acement-2.html
https://www.corvetteforum.com/forums...arts-list.html
Old Feb 2, 2015 | 02:30 PM
hitekcm's Avatar
hitekcm
Hey thanks I will do that by the way its a ZF-,6 speed.
Seller said they drove it shifted fine in all gears and engine runs great.
Old Feb 3, 2015 | 05:40 PM
hcbph's Avatar
hcbph
my 86 convertible came with the DN 4+3. Some time around 10 yrs ago (best guess based on s/n on it) the tranny was changed out for a Tremec TR3550 5 speed. I have been under the car and cannot find any hacks done down there. The only mod I did find was a DakotaDigital unit to change the signal out of the tranny so it works with the original dash.
Old Feb 4, 2015 | 09:19 AM
hitekcm's Avatar
hitekcm
Thanks, I don't know if you noticed my other post about buying a complete LT-1 engine and ZF6 trans with all goodies . Came out of a 95 with only 80K miles on it so I'm hopping for a semi-easy swap?
Got off ebay from a wrecking yard in Texas for $1500 .
I amm currently looking at shipping options.
Old Feb 4, 2015 | 09:49 AM
hcbph's Avatar
hcbph
Actually did notice but not knowing that tranny just mentioning there may be a few more details to deal with. Aren't you going to have some form of C-beam adapter for that tranny? Just some thoughts. Other thing would be shifter location in the car, will it work out?
If you got what you want, more power to you. Hopefully you got everything you need for the conversion.
Old Feb 4, 2015 | 10:12 AM
DanZ51's Avatar
DanZ51
You said six speed so I ***-umed it was a T56. A complete LT1/ZF should be a great swap. I know they're some ZF swap threads that will give you all the info. The LT1 swap might be a little more involved, but I would imagine someone has done it before. Have at it!
Old Feb 4, 2015 | 05:05 PM
hitekcm's Avatar
hitekcm
Default LT1 swap from a 4+3
Old Feb 8, 2015 | 08:46 AM
HlhnEast's Avatar
HlhnEast
Since '88(?) and up cars came with the ZF, I would think you could source a six speed console so you wouldnt have to mod anything but the trans tunnel maybe.
Good find and price on the LT1/ZF combo. Hope everything is ok with it and you get it to you in a reasonable time and cost.
Good luck!
Old Feb 8, 2015 | 02:12 PM
hitekcm's Avatar
hitekcm
Yes thanks, by the way for future reference about shipping I used YRC freight or Yellow from Waco, Tx to California $168 . Of course the seller has a forklift so that saved some plus they ship to a distribution point in Ca where I have to pickup and they will put into the back of my Pickup truck.
To 88 doug nash conversion question
