FUEL Gauge
Old Feb 2, 2015 | 07:56 PM
ZR1OUS's Avatar
ZR1OUS
Default FUEL Gauge
I know this has been beaten to death so I will be breif. Can someone steer me in the right direction as to how to remove my fuel sending unit? I have search for about 1.5hrs and cant find the step by step instructions.TIA Kevin
Old Feb 2, 2015 | 08:31 PM
l98tpi's Avatar
l98tpi
Max G’s
The fuel pump/fuel gauge sending unit are one piece. Well kinda, you can just swap out fuel pump alone from the sending unit. The fuel sending unit is where you put gas in at the back of the car. Basically, you remove the fuel access door, spill tray, remove your send and return lines from the sending unit, unplug the electric connector, then remove the bolts that bolt the sending unit to the fuel tank. It is not a difficult job. Actually pretty easy on the C4. After a couple times, you can remove the sending unit in about 15minutes.
Old Feb 2, 2015 | 09:07 PM
ZR1OUS's Avatar
ZR1OUS
Iam confused, So you are telling me I dont have to access it from the floor of the trunk/rear hatch area? I want to clean up the sender because the fuel gauge is reading empty.
Old Feb 2, 2015 | 09:21 PM
z06scentair's Avatar
z06scentair
Kevin
Open the gas lid door and remove the torx head (4) t-10 screws from each corner.
Once the door lid compartment is removed it's pretty easy to access.
Call if you need help.
Old Feb 2, 2015 | 09:26 PM
ZR1OUS's Avatar
ZR1OUS
Originally Posted by z06scentair
Kevin
I did not think it was that easy thanks for the help guys. Iam off to Cali. tomorrow but when I pass back through Iam going to tackle it. I assume I should disconnect my battery?
Old Feb 2, 2015 | 09:38 PM
gdl2165's Avatar
gdl2165
Here's a good writeup for you
https://www.corvetteforum.com/forums...h-article.html
Old Feb 3, 2015 | 12:49 AM
ZR1OUS's Avatar
ZR1OUS
Originally Posted by gdl2165
Thanks thats exactly what I was searching for.
Old Feb 3, 2015 | 07:09 PM
reg_255's Avatar
reg_255
Here is a You Tube Video (not mine) I'v been looking at.
My gauge reads it has more gas than it actually does.
To FUEL Gauge
