fan relay location??
Old Aug 8, 2002 | 09:57 AM
AS84's Avatar
AS84
Default fan relay location??
Is it on the firewall behind the battery?
Old Aug 8, 2002 | 10:00 AM
ZylaRace's Avatar
ZylaRace
Default Re: fan relay location?? (AS84)
Don't know about the 90, but they are generally loacated on the side of the radiator shroud. R or L side. They are the same ones used by the MAF,... if you remember what those look like. 1" oval, 2" tall.
Old Aug 8, 2002 | 10:29 AM
vettmech's Avatar
vettmech
Default Re: fan relay location?? (ZylaRace)
On my 85 the primary relay is on the left fenderwell by the master cyl and the secondary relay is on the firewall under the brake booster
Old Aug 8, 2002 | 11:07 AM
Steel Blue 91's Avatar
Steel Blue 91
The fan relays on my 91 are on the L side of the radiator shroud.
Old Aug 8, 2002 | 05:14 PM
AS84's Avatar
AS84
Default Re: fan relay location?? (Steel Blue 91)
There are two relays mounted on the drivers side of the radiator.....I'm working on a fan switch :cool:
Old Aug 8, 2002 | 05:46 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Maybe this will help.
To fan relay location??
