Low Temp Fan Switch
Old Aug 8, 2002 | 10:04 AM
69and88's Avatar
69and88
Default Low Temp Fan Switch
I got one of the low temp fan switches from MIDAMERICA, that kicks on the fan at 180. My understanding was that this kicks on the main fan at 180, but only my auxilary fan comes on at 180 and the main fan still comes on at 225-230 (cant remember for sure). Is this how the new fan switch is supposed to work? The auxilary fan doesnt do much to keep it cool and ends up running all the time since the temp is usually above 180 and it doesnt drop it very fast.
Mike
Old Aug 8, 2002 | 10:32 AM
vettmech's Avatar
vettmech
Default Re: Low Temp Fan Switch (69and88)
HHHhhhmmmmmm....... that doesn't sound right........are you sure you replaced the correct switch?............ running the aux fan won't do squat without the primary fan running..........
Old Aug 8, 2002 | 10:33 AM
ZylaRace's Avatar
ZylaRace
The low temp switch only controls the Aux radiator fan (relay). The primary fan is still computer (ECM) controlled. You will need a new PROM to change this. It is an easy change for someone w/ the tools.
i.e. Yes, it is operating as it should.
I presume you have cleaned in between your radiator and AC condensor, and or added "water wetter" to the coolant......
[Modified by ZylaRace, 8:35 AM 8/8/2002]
Old Aug 8, 2002 | 10:54 AM
69and88's Avatar
69and88
Default Re: Low Temp Fan Switch (ZylaRace)
Thanks ZylaRace, thats what I wanted to confirm.
It does help to some extent, but not as much had the main fan been controlled by the fan relay and new switch.
Old Aug 8, 2002 | 11:00 AM
vader86's Avatar
vader86
its working correctly, but you can wire it so that it does make the main fan come on
otherwise youll need a chip programmed to make the main fan come on early
Old Aug 8, 2002 | 11:53 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The guys are right on the aux fan relay.
I posted a C4 Tech Tip on how to wire the aux fan sw into the main fan relay so that it brings on both fans. It only requires two splice connectors, matching spade lugs and a small section of wire (all available from Radio Shack).
To Low Temp Fan Switch
