I posted this topic a bit back and noone responded so I'll try again...
With the car running if I turn on the headlights I get that interior beeping sound just like if you did the same thing with the keys out of the ignition and left your lights running.
Anyone know what I can do on this? That beep is killing me, good thing the radio is loud. :lol:
You have a ground wire problem somewhere. Check and clean all the ground wire connectors. There are some also under the dash. However, I think that the culprit is one of them in the engine compartment. Clean the main ground from the battery first and then the one that goes from the engine to the body. The one from the engine to the body most likely is the culprit. It should be located at the back of the engine near the battery.
