opinions,advice,Knowledge,personal experience
Old Feb 4, 2015 | 05:33 PM
gman35's Avatar
gman35
Default opinions,advice,Knowledge,personal experience
Long title but all are welcome..putting new hooker long tube headers on my 1987 c4 with a L98. I have a air pump delete kit and also a converter test tube. I am thinking about gutting that air pump finally.. has anyone done this mod?? and how happy were you afterwards with the results.. thanks, gary
Old Feb 4, 2015 | 06:57 PM
playsdixie's Avatar
playsdixie
since you're in Fl, no problems with the air delete....many on this forum have done it, you can do a thread search...you may have to fashion a bracket and change the belt to do it correctly...don't know if it really gives you a lot extra in HP but it sure does clean up the engine bay....
Old Feb 4, 2015 | 08:28 PM
HlhnEast's Avatar
HlhnEast
When are you planning on doing the header install? I would like to see how bad a job it is and fitment on the Hookers and I would be glad to lend a hand. The AIR delete isnt a big job but you may need a shorter belt, at least I did. I had to grind on my alternator case just a little but I am thinking it may not be a stocker.
Old Feb 4, 2015 | 09:24 PM
gman35's Avatar
gman35
Default pm you back
Hey, i will pm you in a minute with deyails.. thanks, Gggg
To opinions,advice,Knowledge,personal experience
