fuel rail
Old Feb 5, 2015 | 05:04 PM
kanvasman's Avatar
kanvasman
Default fuel rail
OK, I snuck over here from the C3 side, I am putting a stock L98 engine into my C3. I have the pump, lines etc all worked out except for one problem. I have a fuel rail that has 2 Saginaw 3/8 fittings in it. I have a set of c4 fuel lines from the rail to the frame with one 3/8 saginaw and one 5/16 saginaw. I am installing nylon OEM type lines, and would like to keep the 5/16 fitting, since that is what the return line is. Does anyone make a reducer to go from the 3/8 to 5/16 saginaw? If not, what year c/4 had the 2 different size fittings in case I need to look for a fuel rail set up like that. Also, I don't want to do the AN set up. Thanks.
Old Feb 5, 2015 | 07:42 PM
aDigitalPhantom's Avatar
aDigitalPhantom
Are you talking about the 16mmx1.5 oring, and maybe the 14mmx1.5 oring fittings that are similar to a power steering hose?
Old Feb 5, 2015 | 07:49 PM
kanvasman's Avatar
kanvasman
yes, those are the ones.I didn't realize some of these rails have different fittings ( supply & return) and some are the same. And they are all for the corvette, since they are om the r ( passenger) side.
Old Feb 5, 2015 | 08:17 PM
aDigitalPhantom
What fittings does the car side have?
Old Feb 6, 2015 | 04:25 AM
kanvasman's Avatar
kanvasman
the car has one that is 16 and one that is 14 ( I think those might be the right numbers). One is larger- the supply for the 3/8 line, and the other - the return for the 5/16 line, is smaller.
Old Feb 6, 2015 | 07:42 AM
aDigitalPhantom
I doubt the C3 will have metric fuel fittings, but I don't know what they are. In order to find an adapter the fittings for both the engine, and the lines in the car it is going in are needed.
Old Feb 6, 2015 | 07:44 AM
ghoastrider1's Avatar
ghoastrider1
love to see a pic of it when finished.
To fuel rail
