Help with clutch problems
Old Feb 7, 2015 | 02:48 PM
Mohammed_z's Avatar
Mohammed_z
Default Help with clutch problems
here is the story ,,
clutch slips when racing from a dig..
Bought new clutch , it doesnt fit. It turned out to be f-body kit that has sprung disc.
Replaced it with the right part number , I got valeo clutch kit 52802203
+ bought new master and slave.
Mechanic told me , fork is damages so i had hard time finding one.
Now he is saying the disc is too thick !! and this will result the fork will hit the pressure plate...
Bellhousing is correct part number and dual mass flywheel. I have no idea if the disc is really thick or i have another problem.
The old pressure plate has signs of scratching caused by the fork.
What do i need to check ???
Old Feb 7, 2015 | 03:26 PM
blue94's Avatar
blue94
That should be the correct clutch kit. Problem could be the fork or the ball stud being worn, with new fork I would look at the stud.
