Whining Alternator
Old Feb 12, 2015 | 09:03 AM
ClaudioC4's Avatar
ClaudioC4
Default Whining Alternator
My alternator has begun to whine. Is it ok to spray a little wd40 to see if it lasts a little longer? Is there a rebuild kit available, or is replacement the best option if it will not quiet down?
Thanks!
Old Feb 12, 2015 | 09:35 AM
WVZR-1's Avatar
WVZR-1
Thanks!
Without knowing the year and which alternator is on the car presently it's difficult to recommend changes. If it were an early car with anything other than a CS144 then it might be an opportunity to improve the charging system.
What year? Is there any information on the alternator case that you can read?
Old Feb 12, 2015 | 09:45 AM
ClaudioC4's Avatar
ClaudioC4
It is a 1985, looks like the original alternator. The car is an early 85.
Old Feb 12, 2015 | 09:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
Wouldnt spray anything in the alt good opp to upgrade as said above
Old Feb 12, 2015 | 10:16 AM
WVZR-1's Avatar
WVZR-1
I don't see the thread right off but I believe an '85 might likely be the best candidate for a CS144 conversion. I believe the upper bracket of the '85 works well and even if an '86 or later is upgraded to a CS144 the '85 upper bracket is suggested. I'll search for the thread but best I recall someone mentioned a CS130 because he had one, I mentioned what was needed likely and later in the thread someone mentioned the CS130 was a "waste" and the '85 upper bracket made the CS144 a breeze.
Here's the thread. Disregard the '86 conversation and go down a few posts where the CS144 is mentioned.
https://www.corvetteforum.com/forums...n-an-85-a.html
If you're concerned with originality and you can determine that it actually is the OE then I'd rebuild/repair what you have. An original would be stamped 1105585, 1105450 OR 10479865 I believe.
To Whining Alternator
