1996: Where to install MSD ignition box?
Old Feb 13, 2015 | 03:45 PM
1984Z51auto's Avatar
1984Z51auto
Default 1996: Where to install MSD ignition box?
I am looking for a good place to put an MSD 6AL ignition box in a 1996 LT4 Corvette. There is a lot more stuff under the hood on this one than there was on my 1984. If anyone has found a good conflict free place please fill me in. A pic or two would be appreciated. TKX
Old Feb 13, 2015 | 03:58 PM
GJ Camacho's Avatar
GJ Camacho
[attach]47847863
Old Feb 13, 2015 | 03:59 PM
GJ Camacho's Avatar
GJ Camacho
No one to date have done this or at least I have not seen another. This is my 93. Hope this helps.
Old Feb 13, 2015 | 04:15 PM
1984Z51auto
That looks interesting, is your hood the stock one and the box clears??
Old Feb 13, 2015 | 04:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
More its away from heat vibration and other electronics the better.
Follow the instructions to a T esp with wiring so you dont encounter rfi (hope the term is right) type issues
No offense Camacho but slap who told you that was a great idea
Old Feb 13, 2015 | 05:19 PM
vader86's Avatar
vader86
There should be room in the well under the headlights, most people put it there.
Old Feb 14, 2015 | 07:21 AM
GJ Camacho's Avatar
GJ Camacho
Yes it's the stock one and no issues with clearance. If you choose to do it like that let me know and I'll give you the specks. Super easy.
Old Feb 14, 2015 | 07:26 AM
GJ Camacho's Avatar
GJ Camacho
No one told me, I came up with. I just can't see anywhere else without it being a crappy job. The pics on the internet that were available showed hacked jobs on the fire wall. Anywhere in the engine compartment has heat. Inside the glove box? Nope, tacky. Give me a better solution with a pic. Thanks.
Old Feb 14, 2015 | 07:28 AM
GJ Camacho's Avatar
GJ Camacho
Do you have pics or point the way to them? Thanks.
Old Feb 14, 2015 | 12:18 PM
armysnipe's Avatar
armysnipe
Installed in the passenger headlight well on a 93 coupe.
Old Feb 14, 2015 | 01:30 PM
383vett's Avatar
383vett
Bottom line is, what does your car run (time slip)?
Old Feb 14, 2015 | 09:00 PM
1984Z51auto
Thanks to all for the ideas.
Old Feb 15, 2015 | 09:18 AM
Crash594's Avatar
Crash594
This might be a dumb question but I don't know much about msd. Does this work with the factory computer for the fuel injection or is there more to it. I tried to read up on it at the msd site but it really does not say.
Old Feb 15, 2015 | 10:29 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yes, it works w/the factory computer. All the MSD box does (when it works), is be an "on/off" switch for the coil. In other words, it replaces the stock ignition module.
Old Feb 15, 2015 | 01:58 PM
383vett's Avatar
383vett
As Cuisinart mentioned, the ideal mounting area for MSD boxes in the coolest area with the least vibration. If you look at where the pros in Nascar and NHRA mount their boxes, you will see that they are in the cockpit. The top of the motor is the worst place to put the thing. Can't get hotter, can't have more vibration. May look cool, but far from optimal.
Old Feb 16, 2015 | 10:48 AM
vader86's Avatar
vader86
Ran a simple forum archive search and found several with LT1/4 engines who put them in the space under the headlights.
Old Feb 16, 2015 | 05:17 PM
1984Z51auto
Thanks vader86. It looks like that is a good place to fit one in without a lot of fab work. I really do not want to hack up the car to get it in.
Old Mar 6, 2022 | 06:27 PM
markjones30's Avatar
markjones30
47847863
Sorry about commenting on a old post but whats with the edlebrock fuel gauge and joints? whatd you buy to do that I want that on my 96 grand..
Old Mar 7, 2022 | 09:10 AM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
The OP and GJ Camacho have not been active on the Forum for four years. You may want to start a new thread on the subject.
To 1996: Where to install MSD ignition box?
