professional help...Hunt and Knight??
No, no and no. Theft system, it wouldn't even crank (starter wouldn't run). Fusible links, same, or it may crank but not start. Throttle body? Maybe a throttle position sensor...are you showing a check engine light? If so, you do not need a scan tool to diagnose. Use the paper clip method to draw codes and poste them up here.
That is odd. Is the Fuel pressure dropping down to 35 after initial prime, or is the initial prime only going to 35?
I wanna lean towards saying that it should be around 50 while cranking if the oil pressure is above 4 PSI, but I'm not 100% certain.
At this point I would investigate 2 possible problems. 1 that your pump is not priming enough during the 2 seconds that its on with KOEO. 2 that there is a possible clogged injector or non opening injector.
If I recall correctly, my fuel pressure primes to about the same pressure as it has when running with the vacuum line disconnected, if not more pressure. Both with a performance pump and a non performance pump.
OP needs to re-check fuel pressure, and check for codes.
Right, however during cranking if the engine produces 4 PSI or more of oil pressure, the oil pressure switch that controls the running fuel pump circuit will close. If there is an internal or external leakdown in the fuel system, this low priming pressure may happen if he is not checking immediately when it primes as I've noticed with my car. And I agree that 50 is too high, however per factory spec on some TPI engines, (not exclusive to Corvettes) 40-48 PSI if I remember correctly is acceptable running pressure with the vacuum line disconnected as you stated in the later part of your reply, running pressure without the vacuum line connected and priming pressure should be the same.
Re-read his symptoms. His problem doesn't occur during start up, and one clogged injector wouldn't cause this symptom either. You are giving bad advice.
I understand. I did forget to make injector plural. If multiple injectors are not opening properly, it can cause a lean misfire on multiple cylinders, which should be enough to kill the engine. From my experience with bad injectors, they were not very noticeable at idle.
Not higher. Priming pressure and vacuum line removed pressure is the same thing; they are both pump running, no vacuum.
Right, under normal circumstances. However, something tells me that if the pump is running while the injectors are flowing less, (engine cranking) the pressure should increase, and if they are flowing more, (engine idling) the pressure should decrease.
I agree.
Here is his symptom:
my 91 L98 starts, idles as soon as you touch the throttle, engine dies and will not start
He said nothing about a rough idle (misfire)
Your fuel pressure operation theory is wrong. The purpose of the regulator (along w/sufficient flow from the pump) is to ensure consistent pressure regardless of injector dwell time. Pressure should be no higher at idle (w/the vacuum line off) than at WOT.
Well, there has been some controversy on whether or not that switch is a backup, or if it is the full time switch and the relay is only for priming that I have witnessed not only on the forum, but on external articles and other C4 social media. Unfortunately through my quick research I was not able to locate any documentation on the second scenario, and I am interested in someone confirming either one by testing it on an actual Corvette.
That's correct, but I didn't refer to his engine having a rough idle. Simply what I was saying is that it may be injecting enough fuel to keep it running at idle, but during a rev there is not enough acceleration enrichment due to a mechanical fault to keep it running.
Your fuel pressure operation theory is wrong. The purpose of the regulator (along w/sufficient flow from the pump) is to ensure consistent pressure regardless of injector dwell time. Pressure should be no higher at idle (w/the vacuum line off) than at WOT. Okay, well, it's only a theory. Now that I think about it I agree with you. Sometimes I get a little confused planning out ideas in my head without writing them down.
1. read the FSM.
2. go out to your car, unplug the oil pressure switch see if it starts. It will start...proof that the fuel pressure relay is providing power to the pump
If the car had to wait for oil pressure at every start up, you'd have a lot of extended crank times, don't you think? Oil pressure switch is a back up.
Copy that, on the rest of what you wrote.
1. read the FSM.
2. go out to your car, unplug the oil pressure switch see if it starts. I'd rather not. I finally got it running right. LOL. Next C4 I come across I will try it on. Haha It will start...proof that the fuel pressure relay is providing power to the pump
If the car had to wait for oil pressure at every start up, you'd have a lot of extended crank times, don't you think? Yes I think so. However I do know for a fact that it at least primes using the relay. Which is what part of the other scenario was.Oil pressure switch is a back up.
Back on topic, you say it starts and idles. Then you touch the throttle and it dies and will not restart. When does it not restart? Right away? Or is it ok after sitting for a length of time?
Did you test for spark during cranking when it does not start (spark tester)?
Injector pulse during cranking (test light can be used)? If you don't know what this is. Youtube, ditto for the spark test. Both are simple tests.
If you don't own those, they are like $10 a piece, maybe, get them. You cannot diagnosis computer controlled cars with NO tools.
If you think your 91 is bad.........LOL.........if you only knew about the current stuff and things coming in 5-10 years=Mind Blown. Not trying to be a jerk, just giving it to you straight.
As Tom said, any codes? If you don't have a scan tool, you can do it with a paper clip (do a search) or via the buttons on the Driver Info center (need factory service manual for that one).
How does it idle? Smooth or rough?
Any colored smoke out tail pipes?
The more info the better. This is how "technicians" diagnose vehicles with information from customer, observation, and testing.
FYI, IDK what your experience has been with dealer service but if it was with something more than about 10 years old....it would not surprise me. Most guys don't want to mess with old car and few car capable of doing so.
I fixed a 94 Nissan 300ZX the first time with a bad miss. No codes either. 1 bad fuel injector. It was SOB to replace. I hated every minute of that car....and it was a LOT of minutes, but it was fixed. SO many vacuum lines and plastic that turned to dust.....it was POS.
