Cracked Valve cover
Old Feb 16, 2015 | 11:55 AM
ClaudioC4's Avatar
ClaudioC4
Default Cracked Valve cover
I found a crack on the valve cover of my 85 Vette when I was replacing the gasket today.
I need to replace the covers, any recommendations?
I would like to stay under $100.
Old Feb 16, 2015 | 03:41 PM
indianavette's Avatar
indianavette
If you're interested in a replacement, I have one good stock cover off an '84, which I think matches your '85. Will get you pix later today or tomorrow. Would ask $35 plus s/h from central Indiana.
Old Feb 16, 2015 | 04:29 PM
ClaudioC4's Avatar
ClaudioC4
I am interested, I need the passenger side. As long as there are no cracks, dents, etc...
Old Feb 17, 2015 | 01:01 AM
Cliff Harris's Avatar
Cliff Harris
Since you have cast iron heads, you can use any Chevy small block valve cover from 1957 through 1986E. That's a lot of possibilities unless you require something that looks good.
Old Feb 17, 2015 | 01:39 PM
ClaudioC4's Avatar
ClaudioC4
Would these work? Never seen them before but found them on CL
Old Feb 17, 2015 | 01:48 PM
ClaudioC4's Avatar
ClaudioC4
Old Feb 18, 2015 | 08:02 AM
tunedport85inject's Avatar
tunedport85inject
C4's may have clearance issue in the wiper motor area if covers are taller than stock,old style perimeter bolts valve covers work.This one on the pic seems a bit tall...
Old Feb 18, 2015 | 12:58 PM
indianavette
Hey there in the frozen north. You have a reply to your PM.
Old Feb 18, 2015 | 09:21 PM
HlhnEast's Avatar
HlhnEast
I have taller covers on my '85. They are close but still clear. Pic on my sig to the left. Cheap cast aluminum ones from eBay. Paid $80. Search SBC valve covers.
Old Feb 18, 2015 | 09:29 PM
Extreme Dimensions's Avatar
0Extreme Dimensions
Former Vendor
I found this on ebay
$114 shipped, but anytime I find an aftermarket OE part like this on ebay, I know it's out there for another 30% off somewhere. Good luck on the parts search!
Old Feb 18, 2015 | 10:52 PM
JackDidley's Avatar
JackDidley
Wow, I had those on my C3 back in the 80s. Wrinkle black, milled high spots. Pretty cool at the time.
To Cracked Valve cover
