Oil pan gasket question
If you are lucky, the crank will be in the correct spot and the pan will come right out. Also, if you plan to change spark plug wires, now will be a good time. With the oil pan out of the way, you have access to the optispark. You will still have to route the wires through the "black hole" on the driver's side, but at least you will be able to plug into the optispark without scraping all the skin off your hands.
Finally, not sure what studs you are referring to, but if you are talking about the locating studs, they come with the fel pro kit.
use the fel-pro os 34500 r 1-piece gasket, fits sbc engines with 1-piece rear main seal from 1986 and newer. the earlier engines with the 2-piece rear main seal had 2 thickness's on the front of the pan and you had to measure the depth of the pan lip, but the gasket kit had both seals in it.
The L98 difference is not in the thickness of the rail sections. I think it has something to do with the later L98 engines with one piece rear main seals.
The oil pan has to slide forward a bit to get into place and I think studs are going to interfere.
I still put RTV into the corners of the one piece FelPro gasket....just to be sure....but up to you.
If you replace the oil filter adapter gaskets that come in the FelPro box which is a royal PITA to get the old gasket out.....I found that now the two torx oil filter adapter bolts are 1/2 a thread too long and do not fully seat. I had to use a dab of RTV at the bolt head to seal it up.
Good luck.
If your planning on replacing the pan gasket with the engine in the car, using pre installed studs and sliding the gasket and pan up onto them is much much easier than trying to hold the gasket in place, manuever the pan into place, start a bunch of capscrews, etc.
How did you jack the motor up. Block under the oil pan before you pulled it?
yes I used a large block of wood, wide and long, not necessarily thick, under the pan to raise the engine; it only needs to come up an inch or so, much more and the sensors on the back of the engine block will hit the firewall
Overall I would get all of that out of the way and make sure the gakset goes in right the first time. Fel-pro provides some handy plastic studs that will hold the gasket in place. Pulling the motor mount is probably easier as mention above but, I was able to use those plastic pegs as is in the back. For the front I trimmed them off and was able slide the pan under. Having the motor raised would have been easier but I already had the required sealer in the corners of the pan so needed to expedite the install.
Go for it - You'll be fine. If not you'll learn something and then be fine. Still be money ahead and either have a clean driveway or find the next leak. I found my power steering has a small leak after fixing the pan gasket, timing cover and valve cover gaskets.
These ol ladies are needy
obviously remove oil and filter.
take off one diagonal frame brace. i took off the passenger side.
move the starter out of the way (2bolts) i set it on top of the fuel lines.
there are some wires that run beside the pan with the plastic push pin style fastners try to pinch the ends and get them out
wipe it all down if it was like my 85 its disgustingly dirty wipe it down
remove the bolts some are studs some are bolts some have heat deflection plates attatched to them.
i drew a simple diagram on a piece of paper so i knew how it went back.
scraping the cork gasket......i hated that. i used a razor blade and kept it vertical and just scraped and scraped and scraped. get is cccllleeeaaannnn.
use the felpro blue rubber gasket for your year.
i dabbed black rtv, dime size, at the rear corners. mixed reviews on this. i did it and it worked.
in my case, i did not reinstall the long plates that ran along the edges of the pan u will know what i meaan when u see them. my bolts were not long enough with the new gasket so away i went. clean bolt holes in the block if u can. i squirted wd40 in the holes as its all i had back then. now id use brake cleaner so it doesnt affect the torque wrench.
i used a torque wrench and found the specs and sequence online. this was before i had a fsm. do......not......overtighten......get a torque wrench that does inch pounds. obviously if the torque u find id in lbs ft, multiply by 12 for your lbs inch. u will need one for the small pound inch.
if u have any other questions to help u through it,, start your own thread and ill help u out.
oh, if you find u cant get the pan off, like its hung up on something, grab your breaker bar and a 5\8 socket and rotate the engine a 5th of a turn clockwise. go slow and dont be surprised if you feel the bolt tighten a bit before the crank starts to move. the pan is getting hung on the cranks counter weights as the guys said up the thread. turning the engine that 1\5 th of a turn moves the cranks position and keep going in 1\5th increments till u can get it off. for me it was in the right position.
the pan might be stuck really good. the old cork gaskets are a beech to remove. i used a broad thin wood chisel to break the seal. not recommended but u gotta get it off without bending the metal pan rails and without scratching the block. be creative. i was using a hammer and a chisel!!! not recommended!
