Im trying to install a switch for the antenna bypass on my '93.
Per my research the pink wire is one but there are 2 pink wires (#2 and #3 on the pic below) that go into the realy and one (#1) that goes to a connector.
Please advise which wire I need to splice the switch in to. Thank you.
I have seen those posts before but the problem with the '93 is the wires are routed completely different compared to 94-96 cars. I'm having a hard time figuring out which pink wire goes to the antenna since the pink wires from the relay go towards the front of the car instead of towards the antenna like the 94-96 cars.
Anybody with '93 or previous model year can possibly help? Thank you.
I just went through dealing with this in my 91. I installed an amp and 4 6x9 speakers in it. I was trying to figure out which pink wire ran my antenna. In our vert on the drivers side I just stuck a volt meter in the connecter to see which one was delivering the voltage to run the antenna up and down. Obviously turn it on, then have your meter set to volts and stick it inside the connecter to see which one you need to connect to.
