Tilt lock repair
Old Mar 6, 2015 | 10:57 AM
aDigitalPhantom's Avatar
aDigitalPhantom
Default Tilt lock repair
I finished reassembling my steering column yesterday after fixing the lose bearing and worn tilt pins. Now I have a problem I cant find and answer to from searching. I have only found results for lose screws, bad bearings, incorrectly assembled bearing, or worn pivot pins.
The tilt adjustment wont lock. I can move the wheel up, and down the same way as if pulling the tilt lever with out touching it.
Old Mar 6, 2015 | 12:32 PM
WVZR-1's Avatar
WVZR-1
Page 36 in this .pdf is the spring etc involved with latching the detents for the tilt:
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
This is a Fiero column with some differences in column-lock but all else is very basic Saginaw.
Old Mar 6, 2015 | 12:44 PM
aDigitalPhantom
That spring is installed correctly. For some reason I always get the weird problems. It looks like I need to disassemble it again to try and fix this new problem.
Old Mar 6, 2015 | 12:50 PM
WVZR-1's Avatar
WVZR-1
You can assemble missing the detents but it's pretty difficult. Look at pages 27 - 29 of the .pdf.
Old Mar 6, 2015 | 03:05 PM
aDigitalPhantom
I have the column apart again. The detents are there, but will not catch the pin on the other side to lock the column. They try and catch, but if I bump the wheel they wont hold.
Old Mar 6, 2015 | 04:18 PM
WVZR-1's Avatar
WVZR-1
I haven't had one apart for quite some time but you need to install the tilt lever and pull the lever towards you for the detent pins to slip between the housing and the two levers with the notches. Easier for me to do than to try and explain.
Go back to the .pdf at maybe page 26 or so and it's described pretty well. Maybe start at page 23 and then go forward. I don't think the detents are actually engaged and the housing ready for the pivot pins until maybe page 30.
3F5B-14, 15 or maybe 16 in the FSM depending on year.
Old Mar 6, 2015 | 06:26 PM
aDigitalPhantom
Looks like I need to find a replacement detent one of them got bent somehow, and I think that is the cause of the problem.
Old Mar 6, 2015 | 06:36 PM
WVZR-1's Avatar
WVZR-1
I doubt you could bend one. They will appear somewhat staggered because the teeth are segmented so that there's only a 1/2 click on each for adjustments. Both aren't latched at the same time. Here's an eBay housing that you can see the stagger in the detents. This is normal. Could you have bent a pin in the other half of the housing? Maybe but I doubt.
You'll have to remove the tilt pivot pins to start over and I believe you realize and have done that or you couldn't see the detents.
Patience LOL
http://www.ebay.com/itm/1978-1994-CHEVY-PONTIAC-OLDS-GMC-BUICK-TILT-STEERING-COLUMN-HOUSING-ASSEMBLY-/150846936253?pt=Motors_Car_Truck_Parts_Accessories&hash=item231f2d94bd&vxp=mtr
Old Mar 6, 2015 | 08:33 PM
aDigitalPhantom
I learned something new. There are at least two different designs for the detents, and at least two different pin setups. I replaced the part of the tilt housing you linked, and it does not have the correct detents. The lower half of the tilt has 2 pins with different sizes. The replacement housing is setup for one pin in the lower half.
Its not as good as I was hoping but better then it was before, and it works now.
Old Mar 6, 2015 | 11:48 PM
whalepirot's Avatar
whalepirot
Originally Posted by WVZR-1
"http://www.crankshaftcoalition.com/wiki/images/d/d6/Jazzman_Steering_Rack_Rebuild.pdf" target="_blank">http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
That may be real helpful, soon, to myself and Roy!
Old Mar 7, 2015 | 12:21 PM
HlhnEast's Avatar
HlhnEast
Yep. Dave has provided one of the best guides to rebuilding the Saginaw columns available. I used it to rebuild a '90 model Jeep tilt with great results. Since the tilt Saginaw is in all GM and most Jeep vehicles of our era, the Jazzman .pdf is very useful. I wish it woulda been a Vette collapsible column but that part isnt hard either.
Old Mar 7, 2015 | 12:52 PM
WVZR-1's Avatar
WVZR-1
The telescoping/travel aspect of the column is the same/very similar to the C3 and of course Cadillac. I've posted this before I'm sure but if you really want to do the upper tele/travel use Jim Shea's papers:
http://jimshea.corvettefaq.com/?cat=5
Nearly anything Saginaw related can be absorbed from his very well documented papers. Gear boxes and racks also.
Old Mar 7, 2015 | 06:31 PM
HlhnEast's Avatar
HlhnEast
Great link as well, Dave! Thank you!
To Tilt lock repair
