Install your own top?
Old Aug 10, 2002 | 02:55 PM
c4md's Avatar
c4md
Default Install your own top?
Anyone ever install thier own top? Top costs are reasonable but the labor charges are a killer. I used to do it on my British cars but the vette looks a little more difficult.
Old Aug 10, 2002 | 04:23 PM
Mr Y Car's Avatar
Mr Y Car
Default Re: Install your own top? (c4md)
I've installed my own top. Rather easy. You can finish the job in about 4 hours. I found it easy to replace the top with the frame on the car rather than off of the car.
Things to do
Remove all the screwed in trip pieces (front (screwed in), Weatherstripping and side unscrew weather stripping brackets. Remove rear weatherstripping. Then unscrew restraints under rear side window weather stripping.
Now pull off front of top. unclip unscrew front of headliner, then unclip the head liners plastic brackets that go on mid bows. Unscrew top mount point under headliner plastic bracket, There are two mid bows that need top unscrewed from. Then remove the rest of the unit, its just glued on. There is no need to remove headliner.
Clean all contact points and wetherstripping brackets. Buy 3 tubes of goop.
When putting new top on make sure not to glue any fabric which is is the countersurface of the top, glue the loose fabric pieces on the back one on the exterior of the frame and one which mates with the rear weatherstrip.
rescrew bows, appy side tensioners then brackets that contain top on sides then do the front. Let dry and put on wether stripping and headliner.
very easy.
Old Aug 12, 2002 | 04:34 PM
Rick86's Avatar
Rick86
Its not hard, I did mine myself, without any previous experience. Check the archieves, also one forum member made the comment that he could screw up 3 tops and still be cheaper than what the shop quoted him. :eek:
Old Aug 12, 2002 | 07:28 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Install your own top? (Rick86)
I did too. I know there are a few real good posts in here about it that helped. :smash:
Old Aug 12, 2002 | 10:05 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Damn!! I just paid $275 to get mine done a few months ago!!!
Old Aug 13, 2002 | 07:45 PM
Rick86's Avatar
Rick86
Default Re: Install your own top? (lowflyer)
Was that for parts and labor. I paid about that just for parts. Did the installer work for beer :jester
Old Aug 14, 2002 | 05:26 AM
Shonan's Avatar
Shonan
Just did mine and it was a breeze. With some glueing instructions given to me in elementry school days many years back, a cooler full of cool ones and basket full of clothes pins, this job was easy. Clothes Pins you ask? When I glued the back strip, I used these to hold the material together to the frame during the curing period. Placed them side by side to ensure full coverage on the back frame. I think you also will be fooling yourself if you thing you can remove the weather stripping without destroying it. You need to replace these most likely. This was my experience and it was easier than replacing the top on a old VW KG. :cheers:
To Install your own top?
