87 leak between intake and heads
Old Mar 8, 2015 | 08:58 PM
AJ123's Avatar
AJ123
Default 87 leak between intake and heads
Not certain gasket or what. Happens at start up maybe an ounce or more and is only coolant
any suggestions
Old Mar 8, 2015 | 09:29 PM
JackDidley's Avatar
JackDidley
If its not from the thermostat, I'd take them intake bolt out, smear a bit of RTV on it and tighten it back down. If that doesnt fix it, you need to replace the gasket.
Old Mar 8, 2015 | 09:36 PM
rkj427's Avatar
rkj427
Pro Mechanic
More than likely the intake manifold gasket will need to be replaced.
Pretty common issue and repair on this set up.
Old Mar 8, 2015 | 10:36 PM
AJ123's Avatar
AJ123
exactly what I was thinking
will have time later this week
Old Mar 9, 2015 | 01:06 PM
Square's Avatar
Square
If the simple RTV on the outside of the intake works, keep an eye on your oil dipstick to make sure you are not getting coolant into the oil.
Old Mar 9, 2015 | 05:08 PM
AJ123's Avatar
AJ123
I snuggled the two bolts with 1/4 " T40 this morning will see when I get home if the leak sealed up
Old Mar 9, 2015 | 06:30 PM
tbirdsps's Avatar
tbirdsps
I was going to suggest re-torqueing those bolts. I found two loose on my 90, no leak but I torqued them down. I had pulled the upper intake to replace the EGR and that's when I found them.
Old Mar 9, 2015 | 08:06 PM
AJ123's Avatar
AJ123
Funny that is what I did this morning
One was a little loose the one by my finger in the picture
No leaks yet
Will check every day for awhile
Steve
To 87 leak between intake and heads
