OEM partnumbers.
Old Mar 9, 2015 | 07:49 AM
devilfish's Avatar
devilfish
Default OEM partnumbers.
I need to replace the following stuff on a complete stock 1991 6spd vette.
And the local chevy partsdealer here in Sweden is like 20 years old and dont now **** about C4s..
So to get the OEM numbers would help alot.
Stock valvesprings for 113 heads.
Stock valveseals for 113 heads. Both intake and exhaust.
Stock valve locks.
Stock fuelpump.
Brass pilotbearing in the crank for the ZF tranny..
Old Mar 9, 2015 | 08:12 AM
WVZR-1's Avatar
WVZR-1
3911068 spring w/dampner
10214034 O-ring type seal
460483 Int seal
24503856 keepers
10125896 bushing
25163463 fuel pump
I would think those part numbers are still available BUT I'd let your vendor confirm and if you had any questions regarding replacing part #'s just post back. I'm assuming the GM source there is properly affiliated.
Old Mar 9, 2015 | 09:01 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
You might want to take a look at the following links. It is great info for your car. I downloaded the ones for mine.
This is a thread that posted a link to Corvette and other GM parts manuals. There is a download for each year.
https://www.corvetteforum.com/forums...s-catalog.html
This is the site that the link above refers you to. It has the available downloads.
http://www.autoricambi-euroamerica.c...hevrolet1.html
Old Mar 9, 2015 | 10:30 AM
devilfish's Avatar
devilfish
Thanks guys, your the best
Old Mar 9, 2015 | 10:38 AM
WVZR-1's Avatar
WVZR-1
I saw that post the other day and didn't pay attention to it. I use some reference materials that have been with me for years and I always start there and reference from the "oldest original" service part and do the replacing numbers from there. There's certainly some great information there.
My reference material is old enough that I can generally ID what might be considered NOS for most applications.
To OEM partnumbers.
