HELP ASAP...
Old Aug 10, 2002 | 06:32 PM
djbraxton's Avatar
djbraxton
Default HELP ASAP...
Alright here I go, install my rebuilt today, but when I when to install in 4+3 the dam thing won't seat. I tried 4 times and no success, right known I'm at the boiling point . What is going on, have done the tranny removal before, this is getting boring. Anybody please help, did I miss something...
thanks :mad
Old Aug 10, 2002 | 06:51 PM
Caboboy's Avatar
Caboboy
Default Re: HELP ASAP... (djbraxton)
hummmmm, do the newer cars have bushings for the pilot shaft to seat into? that used to give me fits in the 60's when i put in a new motor or changed out the tranny :confused: that's all i can think of, good luck!
Old Aug 10, 2002 | 06:54 PM
LPDesRoche's Avatar
LPDesRoche
Try having someone push in the clutch pedal when you insert the tranny into place. Should work for you.
Unless you are just talking about the OD unit by itself.
Old Aug 11, 2002 | 12:29 AM
djbraxton's Avatar
djbraxton
Default Re: HELP ASAP... (LPDesRoche)
Thanks fellows, haven't tried the to push the clutch pedal yet. Yes it seems tobe not seating in the pilot bearing, have about a little more than a 1/4inch gap, then the movement stops....Will depressing the clutch make the install alot easier.... :confused:
Old Aug 11, 2002 | 12:35 AM
scorp508's Avatar
scorp508
ok with about 1/4" left you are definitely through the clutch, and not aligned with the bearing. You have to make sure the tranny is perfectly level. I fought with my 4+3 for quite a while to get it back in. Did you replace the pilot bearing also? You are either JUST missing the pilot bearing, or the clutch is not aligned perfectly with it and pushing the clutch pedal in like lee suggested may help.
p.s.
Whatever you do, do NOT try to 'pull' it into the bearing buy putting the bolts in now and tightening it. It just won't work. Many a person have broken the mounting tabs off of the super T-10 by trying this. Not fun when you then have to take it out and go have the tab welded back on.
[Modified by scorp508, 11:36 PM 8/10/2002]
Old Aug 11, 2002 | 12:51 AM
djbraxton's Avatar
djbraxton
Default Re: (scorp508)
Thanks for the reply, I fought with this for about 6 hrs. After I recover from laying on the garage floor, I'm going to try the clutch method, if that fails, I start all over again..... :crazy:
Old Aug 11, 2002 | 12:53 AM
scorp508's Avatar
scorp508
Do you have an extra input shaft laying around? That is what I ended up using to align the clutch properly.
Old Aug 11, 2002 | 01:07 AM
djbraxton's Avatar
djbraxton
I wish, that would be perfect. I have had the tranny off before , but this time is a B$$$$.
Old Aug 11, 2002 | 01:08 AM
jfb's Avatar
jfb
Make sure that the transmission is in as far as you can get it when the clutch is depressed or you might have the clutch disc drop.
Old Aug 12, 2002 | 12:05 AM
djbraxton's Avatar
djbraxton
Default Re: HELP ASAP... (jfb)
:cheers: Here's to Lee and All that replied to my plea for help, had the wife push the clutch pedal and the tranny seated....Thanks, now on to phase II of the rebuilt...I've installed the comp 2034 with 1.6 rocker, will this work or will I have to buy some 1.5's
thanks : :cool:
To HELP ASAP...
