94 LT1 backfire
Old Mar 12, 2015 | 07:48 PM
swiftvetc4's Avatar
swiftvetc4
Default 94 LT1 backfire
My 94 LT1 70,000 miles starting poping like a backfire from under hood on full throttle. Besides that runs and idols perfect. Not sure where to start looking. Thanks for any help!
Old Mar 12, 2015 | 07:55 PM
antfarmer2's Avatar
antfarmer2
I have the same year mine did this and got worse fast replaced the o2 sensors is what I thought but while I was under it I did the knock sensors at the same time runs great now
Old Mar 12, 2015 | 08:04 PM
antfarmer2's Avatar
antfarmer2
You can jump the ob connector with a paper clip and read the codes
Old Mar 12, 2015 | 08:54 PM
swiftvetc4's Avatar
swiftvetc4
I have the code test kit from MA motor works. Never throws a code or check engine light.
Old Mar 12, 2015 | 09:31 PM
antfarmer2's Avatar
antfarmer2
Yeh mine did not either till it got real bad I just replaced the two in front of the cat are they the ones that came with it?
Old Mar 12, 2015 | 09:34 PM
antfarmer2's Avatar
antfarmer2
Also I flushed out the block with the knock sensors out had to dig one side out full of crap
Old Mar 12, 2015 | 10:11 PM
swiftvetc4's Avatar
swiftvetc4
My mechanic says exhaust or intake leak causes it
Old Mar 12, 2015 | 10:46 PM
THE 383 admiral's Avatar
THE 383 admiral
Do you hear a exhaust leak Or vacuum leak. A vacuum gauge reading & intake leak test are easy enough.
Old Mar 12, 2015 | 10:59 PM
Benny42's Avatar
Benny42
Check your fuel pressure under load. You may have a clogged filter or a failing
fuel pump issue.
Old Mar 13, 2015 | 10:53 AM
antfarmer2's Avatar
antfarmer2
I agree with the last two posts I rember now I checked my fuel pressure first.......I got bosh o2 and ome knocks off ebay and a afternoon changeing and flushing the hardest part was getting under the car and out lol if they are original money well spent
Old Mar 14, 2015 | 11:08 PM
swiftvetc4's Avatar
swiftvetc4
Fuel filter is new. That was a job! Taking it to a friends shop. Read all my books. Lots of reasons listed for back fire. I did check the spark plug wires OK. Checked air pump OK. Checked pcv OK. Exhaust coming out of both mufflers ( new) OK. Car runs perfect beside that issue. Thanks for all the comments. I try not to get under it when possible
Old Mar 15, 2015 | 10:45 AM
antfarmer2's Avatar
antfarmer2
Make sure you have the short o2 wrench save your butt from crawling in there for nothing
Old Mar 15, 2015 | 03:11 PM
Benny42's Avatar
Benny42
Tape a fuel pressure gauge to the windshield and go drive it around hard. You need to know the fuel pressure UNDER LOAD, then report back.
To 94 LT1 backfire
