Optispark scraping noise.
Old Mar 13, 2015 | 04:27 PM
JC316's Avatar
JC316
Default Optispark scraping noise.
Got my optispark off and apart and it's making a plastic on plastic scraping noise when I spin the rotor. It makes the same noise with the rotor off, so I am guessing that the reluctor wheel is scraping against the housing or the sensor. Is the normal, or is the opti fixing to crap the bed?
Old Mar 13, 2015 | 04:48 PM
antfarmer2's Avatar
antfarmer2
Look another local texan what year is it
Old Mar 13, 2015 | 04:54 PM
antfarmer2's Avatar
antfarmer2
If I had it out would replace it and the waterpump........have both if interested
Old Mar 13, 2015 | 05:44 PM
JC316's Avatar
JC316
Sorry. 92. The water pump is new already, in the middle of a cam swap.
Old Mar 13, 2015 | 06:02 PM
Silver96ce's Avatar
Silver96ce
Pull the metal cover off and turn the shaft to see if the wheel is "wobbling" and scraping the opti sensor. If it is it could be that the wheel isn't flat (it is so thin I don't think it can be easily flattened again) or the bearing is shot allowing the shaft to "wiggle". Also push in and pull out on the opti shaft to see if it will move in and out. If either or both are true, time for a new opti.
Old Mar 13, 2015 | 06:37 PM
JC316's Avatar
JC316
Decided to change it out, not going to risk it.
Old Mar 13, 2015 | 07:23 PM
antfarmer2's Avatar
antfarmer2
Thats what I did hence the extra parts .......I put a bit of locktight on the screws on the cap did not like the look of it
Old Mar 13, 2015 | 07:33 PM
RedCorvette1988's Avatar
RedCorvette1988
Mine was making a scraping noise-- when I took the cap off it was full of rust. It was a wonder it ran-- this was off a 92.
To Optispark scraping noise.
