Front leaf spring
Old Mar 14, 2015 | 07:47 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Default Front leaf spring
OK I need opinions on best replacement front leaf spring to use. As close to stock or one that's softer. Thank You
Old Mar 14, 2015 | 09:55 AM
WVZR-1's Avatar
WVZR-1
This is for an '84?
If yes then I'd think the softer/better ride might be found using the '85/'87 HKX, HMP. That or a specialty spring from an after/market source.
You can't use springs from anything newer than '87 in the front of the '84.
Old Mar 14, 2015 | 09:57 AM
eutu1984's Avatar
eutu1984
No I'm sorry I should have said year, Its for a 90.
Old Mar 14, 2015 | 09:58 AM
eutu1984's Avatar
eutu1984
Thinking of this.
http://www.corvettemods.com/84-96-C4...g-_p_9034.html
Old Mar 14, 2015 | 10:04 AM
eutu1984's Avatar
eutu1984
then there is this.
http://www.vbandp.com/auto-parts.htm...ategory_id=115
Old Mar 14, 2015 | 10:21 AM
WVZR-1's Avatar
WVZR-1
You first need to determine I'd think what it was built with. If you have a build sheet it will have the "spring codes" that it was built with. That is a much more accurate way of determining what is there than relying on the SPID label and RPO codes, but RPO codes should do pretty well I'd think to determine the "what's there".
If you're dead set on buying new you need to rely on the information supplied by the Vendor, the Vendors actually only approximate the rates of what they sell. Controlling the rate is very difficult when constructing new product. I don't believe the technology has improved/changed for the product being marketed/sold presently for the C4's.
If you were interested in a used then you need to be careful. Even though '88+ front suspension would except the later spring the construction of the outer ends was changed and using the later springs in a '88 - '91 might result in something you don't like. I believe the "pedestal" on the spring ends was added in '92, I must stress the I believe.
Old Mar 14, 2015 | 10:25 AM
eutu1984's Avatar
eutu1984
Its base model 90, I will most likely go new.
Old Mar 14, 2015 | 10:31 AM
WVZR-1's Avatar
WVZR-1
If new like I mentioned you need to ask lots of questions of the manufacturer or vendor and don't just rely on the information from a reseller. I have a new VBP spring with a lebel and production information. I was quoted only approximate specifications of that particular "production" run.
Old Mar 14, 2015 | 11:36 AM
eutu1984's Avatar
eutu1984
Did the new spring you used from VBP work OK, on my 90 it just has the flat rubber piece on the ends and does not have the bumper.
Old Mar 14, 2015 | 12:32 PM
WVZR-1's Avatar
WVZR-1
VBP is a rear and not installed.
I don't know this for a fact but I'd think that VBP is only a reseller and their product is likely constructed to their specifications by someone else. I have never asked but it seems like a possibility and I would ask before I bought if I were a buyer today. Do they use multiple manufacturers?
Do you have a failure of the present spring OR?
Old Mar 14, 2015 | 01:11 PM
eutu1984's Avatar
eutu1984
The front spring is starting to delaminate on the underside right in the middle, looks like straw.
Old Mar 14, 2015 | 01:19 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Heres a handy chart
Old Mar 14, 2015 | 01:31 PM
eutu1984's Avatar
eutu1984
thanks for the chart, it looks like my stock spring is about 531 lbs. I may be better off staying close to stock so I dont go to soft up front and to stiff out back.
Old Mar 14, 2015 | 04:51 PM
frankinvett84's Avatar
frankinvett84
I have a FHA from a 94. if interested shoot me a PM
Old Mar 14, 2015 | 05:06 PM
eutu1984's Avatar
eutu1984
Thank You I will consider it and send you a PM.
Old Mar 14, 2015 | 09:15 PM
blackozvet's Avatar
blackozvet
I have put the springs, codes and spring rates here, should help you choose the best spring.
https://www.corvetteforum.com/forums...ar-sizing.html
Old Mar 14, 2015 | 09:18 PM
WVZR-1's Avatar
WVZR-1
Your '94 spring should have a "square bumper" type insulator on each end rather than just the rubber cushion material on the spring. Correct?
To Front leaf spring
Old Mar 20, 2015 | 07:07 AM
eutu1984's Avatar
eutu1984
Update: I decided to order the a new spring from Vansteel, I emailed them to see if they still have a discount code for CF members and they sent me one for a 5% discount.
http://www.vansteel.com/index.cfm?fu...=32033&ID=2877
After I receive and install it I will update.
Old Apr 15, 2015 | 05:07 PM
eutu1984's Avatar
eutu1984
OK I just received the correct front spring from van steel, the first one they sent was for 84 to 87 and had VBP sticker on it, they sent me a new one and paid for return shipping on the other one. It is 3 3/4 wide measuring front to back of the vehicle, the stock one is 4 1/2 inches wide. I called van steel and they said that is fine, also the frame mount pads that came width it are the same with as the new spring. I am in the process of removing the old spring know.
Old Apr 15, 2015 | 06:55 PM
eutu1984's Avatar
eutu1984
I have the OEM front spring out, I am going to degrease and do some corrosion protection and finish up this weekend. The new spring has less of an arch and is thicker.
