Vats module
Old Mar 14, 2015 | 02:59 PM
Simmy1985's Avatar
Simmy1985
8th Gear
Default Vats module
Can some one help, I am trying to find the vats control module on a 1994 c4 lt1, could u tell me if this is a separate unit or is it part of the ccm
Old Mar 14, 2015 | 09:11 PM
WVZR-1's Avatar
WVZR-1
The CCM controls VATS in a '94. What type of a challenge do you have?
Old Mar 15, 2015 | 07:17 AM
Simmy1985's Avatar
Simmy1985
8th Gear
the car wont start not getting any cranking and no power to injectors tried the vats bypass under steering wheel and still nothing. I want to completely bypass the vats system thank you .
this is a pain in my ****
is there a way to completely bypass it
Old Mar 15, 2015 | 07:55 AM
WVZR-1's Avatar
WVZR-1
Is this intermittent OR the car won't crank or run at all? Do you have a steady on SECURITY light in dash, a flashing light OR? Do you have any air bag issues?
What do you have in the DIC with just "KEY ON". (DIC is center of dash screen)
Check crank fuses - should be two I believe one is CRANK and SIR the other CRANK and P/N - CSS Fuse #9 & 10
Is this car an A4 or an M6? auto or manual?
Have you just used the door key in the door to turn on/off selectively?
To Vats module
