Dizzy gear
Old Mar 15, 2015 | 02:31 PM
gregs86's Avatar
gregs86
Default Dizzy gear
Can anyone tell me is .500 the size of the hole in the distributor gear or the outside circumference of the gear itself my distributor won't drop all the way down I have turned the oil pump saft and still won't go. Think I need .491
Old Mar 15, 2015 | 05:24 PM
THE 383 admiral's Avatar
THE 383 admiral
This depends on the year & distributor
.441 - .500 is the OD of the distributor shaft.
Or the ID of the Distributor gear bore.
But irrelevant. You are just mis-aligning the slot on the oil pump shaft. Make sure piston 1 is TDC. Use a long screwdriver or similar aim the oil pump slot at the corner of the valve cover for piston # 1 now smoothly set the distributor in. 3 teeth back from your oil pump shaft. This will align and drop in. Very close to your firing position as well.
Old Mar 15, 2015 | 06:28 PM
gregs86's Avatar
gregs86
I have turned the oil pump shaft to many slightly different positions trying to get it I but it won't drop it was a brass dizzy gear I'm starting to think maybe the brass could be lodged in the cam gear stopping it. Just a thearoy
Old Mar 15, 2015 | 07:24 PM
THE 383 admiral
There is no guarantee with any part or manufacturer.
This theory is just shy of impossible.
I have witnessed a cam gear off by 2deg. Chews up your Diz gear.
But never the distributor gear. This is a perfected cut. I get 1.235 OD
Old Mar 15, 2015 | 08:01 PM
gregs86's Avatar
gregs86
No I was trying to say maybe some of the brass from the cissy gear could be stuck in the cam gear like if you drill aluminum with a drill bit it can sort of form to the groves in the drill bit don't know if that's possible but I have dropped the distributor into this car many times with no problems. Btw this is a zz4 block with a zz8 cam afr heads
Old Mar 15, 2015 | 09:05 PM
Cliff Harris's Avatar
Cliff Harris
Crank the engine and the distributor will drop into place when the oil pump slot lines up with the pin in the distributor gear. If it doesn't drop then you have a problem. If it does drop then you need to line up the oil pump shaft better.
Old Apr 2, 2015 | 12:50 PM
THE 383 admiral
Any results? Are you driving again.
Old Apr 2, 2015 | 01:52 PM
gregs86's Avatar
gregs86
Yes sir back driving
Old Apr 2, 2015 | 01:54 PM
gregs86's Avatar
gregs86
Yes sir back driving. Thanks
Old Apr 2, 2015 | 02:00 PM
gregs86's Avatar
gregs86
I have a new problem. Now the car will start right up and drives great. But every now and then while at a red light she just dies. No codes. Does smell like it's running rich though. Any thoughts ?
Old Apr 3, 2015 | 02:15 AM
Cliff Harris
Do a minimum idle adjustment:
http://forums.corvetteforum.com/1570563689-post1.html
Old Apr 3, 2015 | 10:50 AM
gregs86's Avatar
gregs86
Originally Posted by Cliff Harris
I think I remember reading to disconnect the same wire as when setting the timing. But I don't see that on that link so my question is do you have to disconnect that just to set the minimum idle screw the 4500 RPMs and then plug it back in or do you not unplug it at all.
Thank you in advance
To Dizzy gear
