ASR/TV cable
Old Mar 16, 2015 | 02:21 PM
vetteOnTheRun's Avatar
vetteOnTheRun
Default ASR/TV cable
I will be installing a transgo full race shift kit for my 4l60/700r4. This might sound dumb, but with this shift kit will the TV cable be needed? Also I am not concerned about the asr/traction control can that be be ditched as well? Has anyone done this on a auto transmission? I have seen some guys do this on manual transmissions. Please dime in. Thanks
Old Mar 16, 2015 | 06:19 PM
THE 383 admiral's Avatar
THE 383 admiral
If you are installing a manual valve body. Then yes, the VB kit eliminates the need of the TVS cable. the Governor weights are locked out. Worst mod I have experienced. Especially with the B&M shifter. Sounded cool to have and talk about.
Old Mar 16, 2015 | 06:51 PM
vetteOnTheRun
Hmmm sounds like you had a bad experience by doing this. The valve body I have is being modified for full manual shift for a automatic. Is there a difference between doing this and a true manual valve body?
Old Mar 16, 2015 | 11:41 PM
THE 383 admiral
Same full manual VB with trans cooler. My TA mild build could chirp 3rd hard. That did not last to long. Then lost OD & 3rd it was just a PITA pretending it was a manual. With a flimsy ratchet shifter. PS. A tip. I was told never let your car stall out in gear. With this setup.
I had 3:45 gears, CC 306, 2800 stall it would do the best burnouts easily 200' out on the track. Could not hook up.
To ASR/TV cable
