lt4 sputter
Old Mar 16, 2015 | 06:41 PM
RRPVETTE's Avatar
RRPVETTE
Default lt4 sputter
She is a 96 CE lt4 (Lilith) with 120034k. A couple weeks ago I drove to the store and when I was done I started her up only to have her sputter out on me at idle like there was no fuel. I had just replaced the fpr and figured I would move on to the fuel filter. After that was swapped everything was kosher, a lil rough on idle but not like it was. Then today on my way home from work I stopped by walmart to pick up a few things. 45 mins or so later went to the car and where it normally takes a second or less to start took 3-5 seconds to start and then she tried to die on me at idle again, I have her some gas and as long as I was above 1500 or so I was good. While pulling out of the parking lot she tried it again just going into first. Then again same thing at the next red light, it felt like I had zero response from the throttle once I let off of the clutch. I was being robbed of all power between shifts at low speeds and absolutely miserable acceleration after that. I have a code reader to view the sensors but no clue on how to read them. Someone please help
Old Mar 16, 2015 | 06:47 PM
RRPVETTE's Avatar
RRPVETTE
Oh yeah and after driving for a few mins I was able to sit at idle without having to hold her above 1500. Still idled rough but didn't try to die nor did she try to die while taking off from a stop. I still had that feeling of being robbed though.
Old Mar 16, 2015 | 09:02 PM
touyech2883's Avatar
touyech2883
Does it have a check engine light on?
Old Mar 16, 2015 | 10:44 PM
RRPVETTE's Avatar
RRPVETTE
The only code that is throwing is an EVAP code
Old Mar 16, 2015 | 10:51 PM
touyech2883
Did it have that code before this problem started? What code was it?
Old Mar 17, 2015 | 09:35 AM
RRPVETTE's Avatar
RRPVETTE
P0441 and yes it was there before all this started
Old Mar 17, 2015 | 10:22 AM
touyech2883
Sounds like a big vacuum leak check all your vac lines under the covers and to brake booster.
Pull vac line off fuel pressure regulator make sure it's not bad and pumping fuel I to the vac line( should be dry).
If no prob found with that try unplugging the MAF and then start it see if it clears up.
Fyi p0441 I believe is purge flow problem may need to replace the purge valve.
In very rare case I've seen valves like the purge valve go bad and short out causing computer failure hopefully that's not the case
If still no change then you need to get into checking fuel pressure/spark and a scanner that can read all the sensor data.
hope this helps.
Old Mar 17, 2015 | 12:58 PM
RRPVETTE's Avatar
RRPVETTE
The vacuum line to the fpr is fine, I checked all the others I could find and they did not appear to be leaking. I doubt the computer is fried song as it is only intermittent and not constant. The last time I had a big vacuum leak it was throwing up a lean condition code and I fixed that on the spot (it was the pcv elbow hose on the pass side) bit no codes like that now. And you are right about that code but I have replaced it 3 tones now and I think the canister itself is bad. Or the solenoid. As far as fuel pressure goes when I put a new fpr in the pressure was a couple psi below norm which is why I went to the filter next
Old Mar 17, 2015 | 01:02 PM
touyech2883
Try unplugging the MAF sensor and see if it runs better they will run in a default with them unplugged and if it's the issue it should clear up
Old Mar 17, 2015 | 01:40 PM
RRPVETTE's Avatar
RRPVETTE
Just tried it, the maf read .89-.92 plugged in and .32 unplugged the fuel trim dropped to -1.6 - -.8 unplugged and .8-3.2 plugged in. What does that mean? No noticable difference but like I said it's am intermittent problem so is hard to replicate.
Old Mar 17, 2015 | 01:42 PM
RRPVETTE's Avatar
RRPVETTE
Oh yeah and both times that it happened she was already warmed up and had been driving for at least 15 mins
Old Apr 8, 2015 | 10:38 AM
RRPVETTE's Avatar
RRPVETTE
I think it was the plug wires, she's been doing it all morning and the #2 boot was arcing to the headers. We shall see
Old Apr 8, 2015 | 11:23 AM
lt4obsesses's Avatar
lt4obsesses
http://www.totalcardiagnostics.com/s...their-meanings
Not sure, but the code is more likely an effect and not a cause issue. The first thing I would look at would be the fuel pump. When mine went out, looking back it was giving me warning cues, similar to what you were experiencing. Then on day, it ran great until I got almost home. Then it finally gave up the ghost two blocks from home.
Changing plug wires will help, but I would think if the no2 were arching that bad that it cut power would be getting a misfire code on that cylinder. Either way, if it's arching, change 'em.
But the best way to figure it out is diagnosis. Fuel pressure when symptom present, spark test and go from there.
Old Apr 10, 2015 | 06:05 PM
RRPVETTE's Avatar
RRPVETTE
Another update: still had power loss and rough idle after the wire change. I went to the parts store and picked up MAF cleaner and TB cleaner and thoroughly cleaned both. She's running smooth as silk right now. As long as it holds up then I think that was the problem.
Old Apr 10, 2015 | 07:54 PM
l98tpi's Avatar
l98tpi
Max G’s
Hopefully it is fixed already, but if it does act up again take a look at the connector to the coolant temp sensor just below the throttle body. I had to change my connector on mine and fixed the issue. I would never have found it if we hadn't had put it on dyno and had all he parameters in front of us. We cod see the coolant temp drop to negative default number when it would loose contact.
Old Apr 13, 2015 | 06:29 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 1996 Service manual
1996 Service manual identifies DTC P0441 EVAP System No Flow During Purge
Old Apr 30, 2015 | 01:35 PM
RRPVETTE's Avatar
RRPVETTE
Update: She started acting up again so I changed the plugs from what I had to delco rapidfires and threw on MSD 8.5 wires and absolutely 0 issues. I decided to check the old plugs which were fine wires and about half of them were still at .050 gap and the others were at .070 and it was because that little nipple that sat on top of the puck was gone. My best guess is that they were not rated for my heat range and burnt off. The other reason I was thinking that is because the porcelain was covered in a white powder almost like the porcelain was breaking down due to the heat. But the delcos have no such nipple so I should be fine
To lt4 sputter
