Advice Needed Please...
Old Mar 17, 2015 | 07:56 PM
jodester's Avatar
jodester
St. Jude Donor '14
Default Advice Needed Please...
Gotta '90 vert with 124k miles on her. I've been driving her a lot the last couple of days since we have had some abnormally warm days (78-82). After the car gets warmed up, and its in in the afternoon, I've noticed a slight "surge" on and off at normal around town cruising speeds(35-45mph) I've read the FSM and I'm leaning toward new plugs and wires, does it sound like I'm heading in the right direction? The car does tend to backfire when shifting gears and it already has new air filter, fuel filter and alternater. Thanks
Old Mar 17, 2015 | 08:14 PM
s carter's Avatar
s carter
since the car has taken the winter off I would start off with a nice tank of fresh gas. just to take moisture out of the loop. check your cap a rotor
what you are describing also sounds a lot how my car was running just before the coil died.
put the gas in test out from there
Old Mar 17, 2015 | 10:09 PM
HlhnEast's Avatar
HlhnEast
I had a miss in my ''85 L98. It took $600 and a year to finally get EVERYTHING that was causing issues. New cap, rotor, wires, plugs. Rebuilt dizzy with new ICM, pick up coil and condensor. New ignition coil, new fuel pump, filters, and finally rebuilt injectors got rid of the last of it.
So, start diagnosing and hopefully yours isnt in as bad a shape as mine. Cant go wrong with a basic tune up.
Old Mar 18, 2015 | 07:49 PM
jodester's Avatar
jodester
St. Jude Donor '14
Thanks for the replies.
Don't think it would be the gas, as I have been able to drive it a minimum of one day a week for the past 4 months and I've been using fuel stabilizer. It tends to idle a little high at stop lights until I tap the petal, but does better once at operating temp. I'm thinking I'll also check the TPS and O2 sensors, the throttle body has been cleaned.
Old Mar 21, 2015 | 05:37 PM
playsdixie's Avatar
playsdixie
I would check timing/clean aic out/tps and then minimum idle adjustment all the basics that won't cost you anything....I have to tap mine occasionally and have read threads from others that have to also....don't know what the hell causes it....and as always, check your fuel pressure....
Old Mar 21, 2015 | 05:53 PM
playsdixie's Avatar
playsdixie
did my targa with a $20 piece off ebay...used the war dept's blow dryer..
Old Mar 23, 2015 | 08:15 PM
jodester's Avatar
jodester
St. Jude Donor '14
Not sure you meant to post that to this thread but I assume you applied window perf to your Targa top. That's looks really good and easy to change if you get tired of it later. Just fyi,that stuff only has a life of about a year +/- a few months.
Old Mar 23, 2015 | 09:09 PM
playsdixie's Avatar
playsdixie
yeah, wrong thread....lets all have another drink
Old Mar 23, 2015 | 09:52 PM
antfarmer2's Avatar
antfarmer2
don't mean to jump this thread but I am getting ready to do this to mine due to sun damage did you cut along the metal rim or put the metal over the vinyl?
Old Mar 24, 2015 | 12:20 AM
Cliff Harris's Avatar
Cliff Harris
Mine did that until I adjusted the cruise control cable. Try disconnecting it and see if the problem goes away.
To Advice Needed Please...
