Just finished them. Do will they do properly work?
Mar 21, 2015 | 02:34 PM
Just finished
Tomorrow I will discover if they will correctly ramp C4 without air damn rasping
Mar 21, 2015 | 02:37 PM
Quote:
Originally Posted by
Christi@n
Just finished
Tomorrow I will discover if they will correctly ramp C4 without air damp rasping
One more pic
Mar 21, 2015 | 04:18 PM
I would beval the four wooden edges for a smoother ramp
Mar 21, 2015 | 04:36 PM
antfarmer2
Good idea...
How would you make it? 45° circular saw?
Mar 21, 2015 | 04:39 PM
Christi@n
Good idea...
There's a problem with the second step, there are four screw three centimeter from the edge
Mar 21, 2015 | 06:08 PM
buzz it down with a hand held Makita or similar 4" or 4&1/2" side grinder
Mar 21, 2015 | 06:23 PM
mtwoolford
My ownership...
We call it "la flex"
Mar 21, 2015 | 07:39 PM
Christi@n
My ownership...
I'll remember that next time I'm in an Italian shipyard
Mar 21, 2015 | 08:15 PM
mtwoolford
i'll remember that next time i'm in an italian shipyard :d
:d:d:d
Mar 22, 2015 | 12:31 PM
I just lay down a couple small pieces of 2x10 to drive up on before the ramps (Rhino ramps) and it works fine for me (my suspension is stock).
Mar 22, 2015 | 01:37 PM
Perfect...
Mar 22, 2015 | 01:41 PM
pianoguy
My ramps didn't work properly...
Air damn touched them.. Even with the first wooden table only (the biggest one in first photo)
Mar 22, 2015 | 05:52 PM
Do those ramps get the front of the car high enough to get under it. I was thing about buying a set
Mar 22, 2015 | 06:05 PM
mlm0
You might get under it but play hell doing anything
Mar 22, 2015 | 06:34 PM
mlm0
The black one is 77 € on amazon... Don't know if is available in US,
However need the wooden table to properly work on the front of the car, without the air damn touch
Wooden table are self made
Mar 22, 2015 | 06:35 PM
antfarmer2
Don't understand very well what do you meant for "play hell"
Is it dangerous? Or is it a way to say?
If dangerous why do you think this?
Mar 22, 2015 | 06:46 PM
Christi@n
Allow me to attempt to translate. Yes, I've worked underneath mine while it's been up on front ramps only....and yes it is possible, but with my ample physique, forget about doing very much, since not all that much of me would fit under there...or it's "play hell", i.e difficult to get much done with the car up on front ramps only.
Your results may vary
Christi@n
I am 6'4" and #250 not enough room for me to work
Mar 22, 2015 | 07:51 PM
mtwoolford
Ok think I got it
So are you speaking about that's no room to move well for who have an ample physique,
Then I can relax, didn't you speak about car possibility to fall down, dont you?
I'm 5'7" and 182, so i work well i had recently replace trans fluid
Mar 22, 2015 | 09:15 PM
Christi@n
Ok think I got it
I'm 5'7" and 182, so i work well i had recently replace trans fluid ��
Your good just to ample here
