drive plate torque specs
Old Mar 22, 2015 | 04:33 PM
Buck Stephen's Avatar
Buck Stephen
Cruising
Default drive plate torque specs
can anyone tell me the torque spec for the driveplate mounting bolts
Old Mar 22, 2015 | 07:14 PM
WVZR-1's Avatar
WVZR-1
Nearly 50 hits and "no takers". I'll bite and ask you what type of "boat" are we working on. Nearly every application where the term "driveplate" is used is something other than a conventional connection between the engine and whatever it is that applies/converts the power.
You might also maybe pass on the engine that you're inquiring about.
Old Mar 23, 2015 | 08:05 PM
8a8mfh's Avatar
8a8mfh
Originally Posted by WVZR-1
Nearly 50 hits and "no takers". .
It gets old after a while.
Maybe this person lives in a country where they call the flywheel a drive plate, could be refering to something on the lawn mower, who knows.
Old Mar 23, 2015 | 08:54 PM
Buck Stephen
Cruising
well with this being the c4 thread I figured it would be assumed I was talking about the chev 350 according the the Haynes manual I have a flywheel is used with a standard transmission and a drive plate with an automatic
Old Mar 23, 2015 | 09:34 PM
8a8mfh's Avatar
8a8mfh
And that haynes manual has no torque specs?
Old Mar 23, 2015 | 10:24 PM
Buck Stephen
Cruising
no it does not
Old Mar 23, 2015 | 10:29 PM
8a8mfh's Avatar
8a8mfh
74 ft lbs.
Old Mar 23, 2015 | 10:40 PM
WVZR-1's Avatar
WVZR-1
ASSUMED? A very long time ago I was taught to assume NOTHING.
Actually in GM terminology they're BOTH "flywheels" - in many/most conversations an AT flywheel is incorrectly referred to as a "flex-plate". A flywheel has a ring gear and a flex-plate does NOT.
100Nm (74 lbft) for the A4 flywheel to crankshaft mating flange.
When you're looking for information/help here you might add the year and which engine/trans you're actually working with. In this case the L98/LT1 share the same spec. It isn't to be assumed that ALL C4's are the same - they just ain't
To drive plate torque specs
