84-87 control arm measurements
Thank you,
Alex
Thank you,
Alex
I don't have an early 84/87 CA but I do have a later and using just an inch ruler neither is correct so I'm maybe of no help BUT first of all I'd be looking for a Metric dimension and more importantly the CA isn't based on an isosceles triangle but rather a scalene triangle so I don't understand maybe your mentioning centering based on the upper mounting points.
Whose suspension-member package are you using? Are your SPC CA in factory packages? Part #'s?
I didn't measure the later that I have using a Metric vernier but you mentioned quick and inch measurements so just curiously measuring one the center to center on the shim bolt centers it was 5 1/2". I find it hard to believe that the shim bolt centers early to late would differ by 25mm. Could they? Maybe but I'd be confirming everything you've got first by part # and dimensions provided by SPC.
I don't get the mention of CENTERING by the suspension member vendor.
Maybe to change the geometry of the later '88+ suspension the CA scheme changed that dramatically. I've not checked, but the C4 suspension packages that I'm familiar with and have worked around, a couple SR III packages, another from a Texas vendor and one from I don't know who were all spec'd to later parts.
Post back - it's interesting.
I did find a dimension of 6 3/16" mentioned for another build so I'd certainly be checking everything, the 6 3/16" is center to center on the bracket mounting holes but they're on different elevations so that might alter the dimensioning checks. I quickly plotted the elevation dimensions and the 6 3/16" center to center (on the suspension bracket) and I believe that measuring center to center on the CA would likely result in a 6 3/8" dimension. The elevation difference is 1 3/4" on the suspension bracket I checked.
Here's the bracket that I plotted and used for my dimension. The OP can layout the bracket and measure. I did it very quickly on a piece of scrap cardboard, a straight edge and pencil. Using the proper tools/instruments you could be more accurate for sure.
I am using a subframe built by flat out engineering, the control arms were in the boxes with correct part numbers.
I got ahold of SPC, they told me somehow my control arms got the wrong mounting shaft put on them and are going to mail me the correct part. I have no idea how that even happens on a mass produced part by a massive company like SPC. I thought for sure it was the subframe. both companys were great to deal with tho, I would buy from both of them again. I think its time to buy a lotto ticket lol
thanks again!
Alex
Upper/lower control arms & spindles need to be a match for the frame fabrication. You can NOT mix/match early or late.
If you've a fabricated chassis intended for late then you need all 'late' components!
