84 vette will start with starting fluid
Old Mar 26, 2015 | 10:13 PM
avitiar's Avatar
avitiar
6th Gear
Default 84 vette will start with starting fluid
My vet starts and stays on but to start it I have to use starting fluid. I replaced the fuel pump, fuel filter, fuel pressure regulator, fuel relay switch,and key cylinder . Can any one help??
Old Mar 26, 2015 | 10:53 PM
1984Z51auto's Avatar
1984Z51auto
Is the throttle position sensor voltage set correctly? Is the temperature sensor in the front of the intake manifold working properly (this one tells the computer the engine temperature and so sets starting mixture)? If it is original... its over 30 years old!
Old Mar 27, 2015 | 01:12 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
When you're cranking the starter, are the injectors spraying fuel? I'd guess no, since it doesn't start (but starts on ether) but that would be step 1.
If no spray, step 2 would be checking fuel pressure.
Old Mar 27, 2015 | 06:25 PM
corvettenorway's Avatar
corvettenorway
timing !
To 84 vette will start with starting fluid
