Sometimes my idle is bad. The rpm goes up and down and sometimes the engine stops running.
I can also feel it during ”soft” driving and especially when I’m driving with the cruise control on. It feels much worse now after I’ve changed the fuel pressure regulator to an AFPR.
My EGR is plugged... See mods for more information.
sounds like a dirty throttle body and IAC valve. pull those things and clean them - reset the voltage at your throttle position sensor. when those things get dirty, the idle speed floats all over the place. depending on how many miles you have on them, might as well throw in a new set of plugs, wires dist cap, etc.. hope this helps -
