Question about the Air Temp relocation kit?
Old Aug 12, 2002 | 12:20 PM
champs_97's Avatar
champs_97
Default Question about the Air Temp relocation kit?
Can this mod be used if you are currently running with a cut lid? If yes then where do you connect the IAC? The instuctions I got say to connect it to a part of the filter cover that doesn't exsist anymore.
[Modified by champs_97, 10:25 AM 8/12/2002]
Old Aug 12, 2002 | 12:22 PM
vader86's Avatar
vader86
Default Re: Question about the Air Temp relocation kit? (champs_97)
yup
Old Aug 12, 2002 | 12:39 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
I connected mine on the drivers side of the air filter housing near the snorkle. Sorry no new pics of that yet.
Old Aug 12, 2002 | 12:52 PM
65Z01's Avatar
65Z01
My cut air filter lid had the sides and the rolled portion of the top remaining; there was enough room to drill a hole in the driver side and insert the rubber groumet and IAC sensor.
Old Aug 12, 2002 | 02:04 PM
Steel Blue 91's Avatar
Steel Blue 91
As War Machine said, put it in the trailing edge of the air box (plastic) just left of the snorkle. No need to cut the metal lid for this mod.
Old Aug 13, 2002 | 02:00 PM
champs_97's Avatar
champs_97
Default Re: Question about the Air Temp relocation kit? (Steel Blue 91)
Snorkle :confused: Please explain.
Old Aug 13, 2002 | 02:10 PM
War Machine
The part of the air filter housing that the MAF connects to.
To Question about the Air Temp relocation kit?
