89c4 rear end gear change
Thank you for that bit of information... I had no idea the D35 spiders are a replacement, which would still make my D36 a useful piece, I almost scraped my D36 diff.
I know fore sure that my current set-up will not benefit with a D36, althought the D36 went further then what I expected from it.
2021 C4 of the Year - Modified Finalist
If you actually need the small pinions and washers the Jeep D35 is a fit and I believe readily available. What year is your D36? There's actually a couple carriers and a couple builds that use different pinions I believe.
You shouldn't need the side differential gears. It would be a catastrophic failure that would require those I believe.
Tom's Differentials has a spider gear kit's for dana 36. http://www.tomsdifferentials.com/tomp.htm
