How to remove rear bumper?
Do any of you have any tip on how to do that job?
Thx
If you can remove the mufflers.
Remove rear wheels and liners put safely on stands
Take out L plate and rear backup lights
Remove tail lights because you will need to reach inside for the top bolts.
From wheel start working up to the middle with a 1/4 socket and long extension
At the top I believe I reached in with a 10mm small wrench.
Clean everything and make sure you still have a cushion in there(mine was missing.
I think I just cut the antennae wires marked them and put them back later. Because the connector is inside the car.
Good luck
Good luck
What xrav said. Its a genuine PITA and the more extraneous stuff you can remove for access the better. All I have to say is get used to it,
You cant take anything off these cars without taking something else off.
