Hooker long tube install
Old Apr 6, 2015 | 09:36 PM
gman35's Avatar
gman35
Default Hooker long tube install
Finally got my ceramic coated Hooker long tube Headers installed. They went in without a problem, even though I had to reroute one oil cooler hose. Fitment was excellent, only had to raise car 16 inch's and I had plenty room for the passenger side. I did have to remove the factory front end stiffener at the k frame. Mini starter fits in easily.. now to install my derale deep trans pan.. and button it all up.
Old Apr 6, 2015 | 10:15 PM
ghoastrider1's Avatar
ghoastrider1
after letting it down, be sure to check clearance of that tranny pan and the road. Sounds like your off to a fun summer.
Old Apr 6, 2015 | 11:17 PM
gman35's Avatar
gman35
Default Roger that
Yepper, The car had been lowered from previous owner.. I have a little clearance and believe it will be ok. Headers are tucked up there real good and it looks like my x brace will fit fine also. thanks for the reply, gary
Old Apr 7, 2015 | 01:12 AM
LT195Vette's Avatar
LT195Vette
awesome!!you should post some pics, i think im getting ready to order some for mine
Old Apr 7, 2015 | 07:22 AM
WW7's Avatar
WW7
Unless Hooker has changed there Y Pipe, don't use it...I had to cut mine in 3 places and reweld it to make it fit around my auto trans. It was more work redoing the Y pipe then installing the headers...The headers fit fine, but the Y pipe sucks.......WW
Old Apr 8, 2015 | 08:52 PM
TA's Avatar
TA
I wonder if Hooker redesigned the y-pipe at some point? Although I ditched my y-pipe for true duals a few years ago, it fit perfectly on my car when it was on there (91 A4).
Old Apr 8, 2015 | 09:02 PM
LT195Vette's Avatar
LT195Vette
thank you for posting the pics and the info on the y pipe, ill have to keep that in mind when i get ready to install the headers
Old Apr 13, 2015 | 11:59 AM
spro2395's Avatar
spro2395
Are you relocating the stock o2 sensor? I haven't decided what I'm doing with mine yet.
Old Apr 13, 2015 | 05:07 PM
gman35's Avatar
gman35
Default 02 sensor
No relocation needed on mine.. it is high on the tube, I did install a heated 02 sensor just to be sure.
Old Apr 15, 2015 | 01:12 PM
spro2395's Avatar
spro2395
What heated o2 did you get? I'm getting closer to that step on mine!
Old Apr 15, 2015 | 10:34 PM
ray1979's Avatar
ray1979
I bought the bosch 13077 for $16 and a adapter harnes for $15 have not had any issues since install. Before my car would go into open loop at idle or cruise.
To Hooker long tube install
