Wheel-bearings, need repacked?
Old Aug 12, 2002 | 10:28 PM
dbwade36's Avatar
dbwade36
Default Wheel-bearings, need repacked?
Scraping sound from Right front when turning left or over variences in the road. Does this indicate wheel-bearings bad? (No signs of rubbing on tires/wheel-well). Right side only. If so, what cause the scraping sound? How much should it cost.
Old Aug 12, 2002 | 10:29 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Wheel-bearings, need repacked? (dbwade36)
They are a sealed unit, you'll have to replace it. I've seen them anywhere from $150-$275 each.
Make sure you get the right one, there ones with the ABS plug and ones without.
Old Aug 13, 2002 | 12:29 AM
vader86's Avatar
vader86
I'm not sure that it indicates that the bearings are out, but if your car has close to 100k or over that, then all the bearings and U-joints should be replaced.
Old Aug 13, 2002 | 02:42 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Scraping sounds can be caused by the disc brake pad wear indicators contacting the rotor. Check them in addition to wheel bearings.
To Wheel-bearings, need repacked?
