Blower fan switch
Old Aug 13, 2002 | 02:12 AM
buzzbomb's Avatar
buzzbomb
Default Blower fan switch
The blower fan in my '84 won't work in high position, works fine in the lower three. Do I need a new switch, or is it something else, is it hard to fix? Thanks for any insights.
Old Aug 13, 2002 | 06:29 AM
ol,RJ's Avatar
ol,RJ
Default Re: Blower fan switch (buzzbomb)
I had a simular problem on my 86, it turned out to be the blower motor relay (mounted on firewall near blower on the 86). can't say for sure if thats your problem , but it sounds like it. you could find it by having someone turn the switch to high and back down while you listen for the click of the relay.
RJ
Old Aug 13, 2002 | 07:57 AM
buzzbomb's Avatar
buzzbomb
Default Re: Blower fan switch (ol,RJ)
I'll check it out this morning, thanks. BTW- is this a part I can get at a parts store, or do I need to go to a dealer? Thanks
Old Aug 13, 2002 | 08:40 AM
trupp's Avatar
trupp
If the fan works in all other positions except for high, the problem will be in the blower fan resistor network mounted on the evaporator housing. It's not hard to get to, just one wire harness to disconect and two screws to remove, swap in new one installation is the reverse of removal.
Old Aug 13, 2002 | 11:58 AM
JonM's Avatar
JonM
You should be able to get the " High Speed Blower Relay" at any parts store...its a pretty common part for lots of cars.
Old Aug 13, 2002 | 03:08 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Blower fan switch (trupp)
Is this really what you meant? The resistor pack is only used when not in HIGH. Maybe I'm reading you wrong. I would think if it "works in all other positions except for high" you eliminate the resistor pack and isolate it to the relay or fusible link.
Old Aug 13, 2002 | 03:13 PM
buzzbomb's Avatar
buzzbomb
Default Re: Blower fan switch (Ray Quayle)
So would you think it's the relay also? Is it the relay bleow the fan motor that looks impossible to get to?
Old Aug 13, 2002 | 04:12 PM
JonM's Avatar
JonM
This should clear it up for you....
Not running in Hi= RELAY
Not running in other speeds= Resistor
[Modified by JonM, 3:15 PM 8/13/2002]
Old Aug 13, 2002 | 05:31 PM
buzzbomb's Avatar
buzzbomb
Default Re: Blower fan switch (JonM)
Thanks for the diagram, but I replaced the relay and it didn't help, any other ideas? Thanks for all the help :cheers:
Old Aug 13, 2002 | 06:13 PM
JonM's Avatar
JonM
The only other things I can see is the switch itself or a ground. Here is a elec. diagram.
Old Aug 13, 2002 | 10:55 PM
buzzbomb's Avatar
buzzbomb
It looks like the switch and the relay work, I think the hot for the fan high position is at fault, and may be getting 9 volts if Ive found the right pin. Does anyone no where the fusible link for the fan high hot wire is located? Thanks, Dave
-----------4------
--1--2----------3
-----------5------
The relay block looks like this, I have 12 volts at pin 4 with the fan switched to high, 0 with it on other settings, pin 5 seems to be the ground for the relay switch, pin 3 is the ground for the fan. I think pin 1 is the fan low to med power, and pin 2 would be the high power lead for the fan. It is pin 2 that only has 9 volts with the relay removed. Does anyone know where this wire goes and what connectors/ fusible links could be at fault? I appreciate all the help, Thanks
[Modified by buzzbomb, 3:22 AM 8/14/2002]
[Modified by buzzbomb, 3:24 AM 8/14/2002]
[Modified by buzzbomb, 3:25 AM 8/14/2002]
To Blower fan switch
