Random Stalling
Old Apr 13, 2015 | 06:08 PM
86vett3's Avatar
86vett3
Default Random Stalling
1986 C4 L98 coupe. I've been working on this car for a while now. I got it running recently and I keep having this issue. Sometimes it will fire up and run perfect, but other times when i go to start it, it will stall instantly unless i give it a little gas. IAC valve is brand new, so is tps. It's a completely random occurrence as well, it doesnt matter if its hot or cold or anything. and when it does run, it will stay running perfect until you shut it off. i ran it for about an hour and it was fine, shut it off and its a guessing game on whether it will start again or not. computer is sending out all correct voltages, i tested every wire in the harness with a voltmeter and a chart of the voltages to make sure.
Old Apr 13, 2015 | 06:30 PM
BOOT77's Avatar
BOOT77
Did you check the fuel pressure? How do the plugs look?
Old Apr 13, 2015 | 06:40 PM
antfarmer2's Avatar
antfarmer2
Fuel filter?
To Random Stalling
