Consistent Misfire 1986
If you pull plug wires on a consistent miss, the engine will run worse on every cylinder except the one already missing. If running on seven cylinders and you pull the bad one it should cause very little change. Any other plug wire will have you running on six cylinders.
My bet is that an injector isn't getting consistent power. Pulling the plug wires to identify the bad cylinder is going to be easier than the injector connectors I think.
I would also pull the plugs. are the ones misfiring wet? did you get a bad plug? yes, it happens...cracked on install, etc.
I have had the same problem quite a few years ago, replaced maf, ecm,burn off module, esc sensor, knock sensor, injectors ignition module leads plugs ect. Had spark to all plugs and there were 12 volt pulses to the injector connectors no fault codes i was stumped.
I woke one night and had a brain wave, i went out at 2 am and started the car from stone cold. Ran it for 10 or 20 seconds and turned it off.
Checked the exhaust an inch from the heads, found cylinder #4 cold.
Swapped the injector harness from #2 and found the fault had gone to cyl #2. i was pretty damn happy as the car had sat for around 6 months and i have found the problem.
When the injector connector was flipped over it showed 12 volt pulses, the metal strip inside the connector had broken and would connect when flipped over for testing but would not operate the injector.
I replaced the injector connector the next day and she was fixed, i was very very happy to have found the problem.
We tend to tug at the wires to remove the connector from injector that can damage them.
So start the car when it is cold run it for 10 or 20 seconds and look for a cold exhaust header/manifold pipe, then you know what cylinder is affected.
The injectors are batch fired so you have no problem swapping the harness between one injector of the one near it.
Check the EGR exhaust gas recirculation valve closes.
Good luck
Good luck
Great idea. That should work and has a good chance of being the issue. But what happened to the OP?
