How serious is a leaking steering rack??
Old Aug 14, 2002 | 01:01 AM
Roadster89's Avatar
Roadster89
Default How serious is a leaking steering rack??
Seems I found a new way to spend some money. I have a couple of puddles under the control arms, looks like dark thin oily fluid. Thought it might have been a bad shock, but no such luck. Can I drive it this way? Will it sieze up or break anyother parts before I get around to fixing it? :cry
Any advice would be appreciated. Thanks.
Old Aug 14, 2002 | 01:06 AM
jshope's Avatar
jshope
Default Re: How serious is a leaking steering rack?? (Roadster89)
If you run too low in powersteering fluid, your system will really start to squeal at you. I would keep a quart of PS fluid in the car and if it starts to make lots of noise when you turn the wheel, then fill 'er up. I don't think you should have any major problems as long as the leak is not too bad.
Old Aug 14, 2002 | 11:37 AM
Frodo's Avatar
Frodo
My 89 was leaking really bad around the seal where the steering column shaft goes in, like up to a quart a month if I drove it a lot. I dealt with this for 9 months before I broke down and replaced my steering rack, pump, and all hoses. When it gets low you'll hear a growl coming from the pump, really low and you'll feel resistance in the steering wheel. You might try some power steering sealant, added to the fluid, and see if you can stop it. Driving with low fluid can, over time, cause pump wear. If/when you decide to replace the rack check with a dealer or other source for a genuine A/C Delco remanufactured rack. Some have posted that they were dissatisfied with aftermarket racks. It's a real pain to replace and you only want to do it once. I bought my A/C Delco reman. for $200 from a dealer, less than $50 more than aftermarket racks, and I have been pleased with the fit and performance.
Good Luck!! :flag
Old Aug 14, 2002 | 11:46 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: How serious is a leaking steering rack?? (Frodo)
As long as you can keep fluid in it, it should be okay. I feel sorry for your garage and all the parking spaces that you park in. I watched a lady one time fall in a parking lot by slipping on some oil that a car left. It kind of got me thinking about fixing my cars that have leaks. I would not want that to happen to my mom or my wife or anybody else for that matter.
:cheers:
Old Aug 14, 2002 | 12:07 PM
NeedSpeed's Avatar
NeedSpeed
I've had a slow leak since 1997 (when I bought it). It's still ok. Just got to add fluid periodically.
Old Aug 14, 2002 | 01:49 PM
Roadster89's Avatar
Roadster89
Thanks for the responses, I thought I was going to have to park it for a while. Looks like I'm cruzin this weekend!!
Old Aug 14, 2002 | 04:02 PM
J Z06's Avatar
J Z06
Just keep an eye on it....check the fluid from time to time...keep spare fluid in the car and add it when necessary.
JD
Old Aug 15, 2002 | 09:43 AM
KJB21's Avatar
KJB21
Default Re: How serious is a leaking steering rack?? (JD 90 383)
Have the same problem. Need to drop power steering fluid every once and while. Think I will buy a reman. GM rack soon.
Old Aug 15, 2002 | 09:54 AM
vettmech's Avatar
vettmech
Default Re: How serious is a leaking steering rack?? (KJB21)
yup you'll be fine.......mine's been pouring for about a year now......I will reseal mine and I have the seals but not the time.......it's my only car..... I found some good stop leak at the local NAPA store......... it pours like molasses but it seems to really help ........but it won't fix it.......... and also if it's in there and the car sits overnight in a parking lot it may steer stiff until it warms up in the morning.......... :seeya
To How serious is a leaking steering rack??
