LT4 HotCam + Stock ECM
Old Aug 14, 2002 | 01:16 AM
Hi-psi's Avatar
Hi-psi
Default LT4 HotCam + Stock ECM
Other than obviously not taking full advantage of the combination/power to be made, are there any adverse effects of running the stock programming with a LT4 HotCam for a while?
'94 6spd car.
Thanks.
Old Aug 14, 2002 | 01:19 AM
IcemanZ06's Avatar
IcemanZ06
Default Re: LT4 HotCam + Stock ECM (Hi-psi)
Your stock revlimiter will drive you nuts since the hotcam makes power 800rpms higher then the LT1 cam. You will need to have the ECM calibrated to allow you to take full advantage of the rpm range of the hotcam
Old Aug 14, 2002 | 01:20 AM
IcemanZ06's Avatar
IcemanZ06
Default Re: LT4 HotCam + Stock ECM (IcemanZ06)
I'm a retard and didnt notice that you already knew that. Not any problems that I know of for short term use
Old Aug 14, 2002 | 01:26 AM
Skippy Stone's Avatar
Skippy Stone
Yes/No. If you don't mind inconsitant idle and sometimes unstable low rpm cruise, then no problem. You will perform better from 3000rpm to whatever rpm your max power is at. If the above might bother you, then you must do some re-programing.
Old Aug 14, 2002 | 09:49 AM
Hi-psi's Avatar
Hi-psi
Default Re: LT4 HotCam + Stock ECM (Skippy Stone)
Re-programming is in the plans,....but may not happen for a month or two after everything is back together.
To LT4 HotCam + Stock ECM
