84 Distributor question
Old Apr 26, 2015 | 10:31 AM
skire56's Avatar
skire56
3rd Gear
Default 84 Distributor question
I had to replace the ignition module in the distributor, the hard plastic wire cover/insulator? that is around the wires is crumbling into pieces are these must have pieces and if so where can I get them?
Old Apr 26, 2015 | 12:02 PM
1984Z51auto's Avatar
1984Z51auto
I think you mean the Terminal Block a failure (short) will kill the engine. Here is a link to one source: http://www.taperformance.com/proddet...?prod=TA%5F706
Old Apr 27, 2015 | 01:15 AM
Cliff Harris's Avatar
Cliff Harris
If you're talking about this piece (and its mate), they came with the harness and are not available separately. The harness is no longer available.
Old May 12, 2015 | 07:35 AM
skire56's Avatar
skire56
3rd Gear
Thanks for your reply, is this part necessary or can i use something else? Thanks again
Old May 13, 2015 | 01:42 AM
Cliff Harris
I just used nothing. No problems so far:
Old May 13, 2015 | 01:24 PM
383vett's Avatar
383vett
Looks like mine. It makes the car lighter and faster.
Old May 13, 2015 | 01:27 PM
tbirdsps's Avatar
tbirdsps
You should at least wrap them to give them a bit more protection from chaffing.
To 84 Distributor question
