Engine mods and octane
Old Apr 28, 2015 | 08:11 AM
ps374's Avatar
ps374
Default Engine mods and octane
My 84 has some engine mods. They include Xram intake, TPI fuel pump and changed F.P regulator. Inlarged T.B's, free flow eXhaust with cat removed, 8746 ECM from newer camaro, computer chip, functional Ram Air with butterfly flaps welded open. I was told by the last owner to use 93 octane. Is that necessary?
Old Apr 28, 2015 | 08:17 AM
crowz's Avatar
crowz
Without knowing the chip that they have in it that's impossible for us to say for sure. But isn't there another thread on here active right now with this same question?
Old Apr 28, 2015 | 09:07 AM
JackDidley's Avatar
JackDidley
Really depends on cylinder pressure. Compression ratio on the car. Cam duration and ignition timing too. Stock cam, pistons and heads, you can probably get by with 91. I like 93. It lets me give the car a lot of advance.
Old Apr 28, 2015 | 09:14 AM
tbirdsps's Avatar
tbirdsps
Generally if your gasoline has a 8-10% alcohol content then 91 should do the trick. Alcohol, although it sucks for many reasons, is a good substitute for octane.
Old Apr 28, 2015 | 11:10 AM
Aardwolf's Avatar
Aardwolf
Dupe
https://www.corvetteforum.com/forums...er-octane.html
To Engine mods and octane
