Blown head gasket
Old May 1, 2015 | 12:12 PM
bogus's Avatar
bogus
Originally Posted by mtwoolford
Yeah, in those years, Detroit was caught in the cross fire of the metric revolution; everything on the engine is US standard, almost everything else on the car is metric; "English"? you don't even want to go there unless you're restoring old English cars; imagine telling the slacker at ACE hardware, "Eh mate, I be looking for something in a whitworth thread"
IIRC, the bolts on the L98 intake are metric... the engine bolts are standard...
Old May 1, 2015 | 05:23 PM
mlm0's Avatar
mlm0
Started working on my car today. In process of changing plugs. Going to use ac delco TR5LS which is what FSM calls for at .035 gap So far, after removing the number 8 plug I found it almost gap less, don't know why. The plugs on the pass side sure are pain in butt. I got loaner tool from auto zone today to test block for exhaust gas leak into fuild, but I really don't think it's cracked. I love this forum but I don't like it when people don't advise if or how problem was fixed. I will update as I work on issue.
Old May 1, 2015 | 06:43 PM
desertmike1's Avatar
desertmike1
If the Spark plug has "No" or very little gap, it was probably dropped at one time.. if so, then the rule of thumb is; you drop a plug once, then the second time you drop it should be in a trash can!
A spark plug can be damaged internally and cause a miss fire.
Your doing some really good troubleshooting here..
Old May 1, 2015 | 11:31 PM
mlm0's Avatar
mlm0
I learned a lesson. Not only was there very very little gap, it was also off set. I must have hit it on something while putting it in. Hope to finish the number 2 and 4 tomorrow evening and see if it idles any better. Not holding my breath
Old May 1, 2015 | 11:34 PM
mlm0's Avatar
mlm0
Hope this is my idle problem
Old May 2, 2015 | 07:07 PM
mlm0's Avatar
mlm0
Got all plugs replaced. The two I thought would be hardest, #2&4 were not bad after removing inder fender. Also replaced TPS sensor. Good news it is runing great at this time. I think it was more the plugs. I also found bad spark plug wire connection Now I have to drive it for a while to make sure not losing water
Thanks to all
Mike
Old May 2, 2015 | 07:16 PM
don hall's Avatar
don hall
Thanks to all
Mike
Thanks for posting the results.
Old May 3, 2015 | 09:59 PM
mtwoolford's Avatar
mtwoolford
Old May 4, 2015 | 10:23 AM
desertmike1
Old May 4, 2015 | 12:31 PM
bogus's Avatar
bogus
Amazing what a little diagnostics does!!!
Congrats!!!!
